coolant being pushed up through overflow coolant
#16
Re: coolant being pushed up through overflow coolant
#17
#21
#22
#24
The link opens, and shows that the cap has a rating of "20", meaning 20 psi... which means it opens when the pressure builds to 20 psi (pounds per square inch). The LT1 cap should be rated at 18# (18 psi).
Click on the "Specifications" tab:
It doesn't help that when you do the "check vehicle fit", it shows 18 psi.
Cap Finish: Plated
Cap Material: Steel
Lever Type: Yes
Logo: Yes
Material: Steel
Maximum Pressure: 20
OE Replacement: No
Quick Pressure Release: Yes
Radiator Cap Shape: 4 Ear
Reservoir Overflow System: Yes
Shape: 4 Ear
Cap Material: Steel
Lever Type: Yes
Logo: Yes
Material: Steel
OE Replacement: No
Shape: 4 Ear
This part is an Exact fit for your1994 Chevrolet Camaro Z28
Safety Release Radiator Cap; 18 psi Pressure Rating
#25
#26
ah got it so this cap would be fine? CST/Radiator Cap 7718 at AutoZone.com
#27
okay thats the next thing i will do. Today i was hitting high rpms and it stayed arouned 180-190ish the whole time but last night it was at 220.
