Just recharched A/C, now codes 67 and 69
Old 07-01-2011, 07:53 PM
AdsoYo's Avatar
I just had the A/C recharged at a shop. The A/C system had been empty since May 2009 when I had my new engine put in. Before then it worked great. Now I have codes 67 (A/C refrigerant pressure sensor circuit (pressure sensor or A/C clutch circuit problem)) and 69 (A/C clutch circuit) and the compressor will not engage. These codes did not exist before I had my A/C recharged. The mechanics already left for the 3 day weekend so I'm on my own until Tuesday. Does anyone know what could be wrong?
AdsoYo is offline
Old 07-01-2011, 09:28 PM
Re: Just recharched A/C, now codes 67 and 69
Try resetting the PCM and clearing the codes.
shoebox is offline
Old 07-02-2011, 07:45 PM
sniperSS's Avatar
Yes, first thing clear codes.
sniperSS is offline
Old 07-03-2011, 01:36 PM
AdsoYo's Avatar
Cleared the codes. When I started the car they were gone. As soon as I turned on the A/C, code 67 came back and the compressor did not engage.
AdsoYo is offline
Old 07-03-2011, 02:46 PM
That tells you right where you need to be looking.
shoebox is offline
Old 07-03-2011, 04:30 PM
AdsoYo's Avatar
I also forgot to mention the fans turn on as they're supposed to when I try and turn on the A/C. So is it just a matter of making sure all the wires and connections are good? I did a quick glance and the pigtail is plugged in on the compressor. Any wires or connections in the interior I should check?
AdsoYo is offline
Old 07-03-2011, 05:14 PM
Redneck2009's Avatar
yea im having this issue too only i have not run for error codes yet. my ac is blowing out hot air, replaced compressor, new one still wont engage but fan kicks on. so me and him might be having same problem
Redneck2009 is offline
Old 07-03-2011, 07:06 PM
AdsoYo's Avatar
I took a closer look at the pigtail on the compressor. There are two wires going to the compressor: a black one and a green one. The green one is cut flush with the pigtail. I'm guessing that's my issue? Not sure how that could've happened.
AdsoYo is offline
Old 04-23-2012, 04:13 PM
AdsoYo's Avatar
For closure purposes: after ordering a new pig tail and soldering it on, the A/C works like a charm.
AdsoYo is offline
HectorM52
06-23-2016 08:42 PM
timmy39120
05-08-2015 11:41 AM
alphaauto
02-05-2015 05:25 PM
91Bird305
08-05-2002 01:39 PM
tbyrne
07-02-2002 05:37 PM
Quick Reply: Just recharched A/C, now codes 67 and 69
