Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
in middle of opti swap, no start
Old 05-02-2016, 07:58 PM
RT808's Avatar
I just swapped my opti and wanted to see if it would start with just the harness and coil wire plugged in. cranks but does not start. not even a hint. battery at 100% on the charger last night.
is this normal? Should i put the wp back and everything? i disconnected battery. I did line up the spline on the opti correctly, i lined it up and after couple gentle pushes it pushed right in flush. bolted up
also the opti i pulled spins freely and the rotor screws are tight. it was only a year old and clean inside. Have not scanned for codes since i tried couple months ago. i stupidly disconnected the battery to check wires before i got the cable and software. Car has been down for months after it stopped running on a city street. fuel pressure good and holds.
RT808 is offline
Old 05-02-2016, 09:57 PM
Re: in middle of opti swap, no start
Are you getting any spark?
I know it isn't supposed to matter, but my car never wanted to start without the MAF plugged in. The IAT and coolant sensor might make a difference, too.
shoebox is offline
Old 05-04-2016, 05:14 AM
RT808's Avatar
ok thanks shoebox, i'll try it with MAF and IAT i also noticed that part of the harness that plugs into the opti on the intake. it come off a thicker bundle, but that part that hooks into the opti harness...it looks ratty. i'll take a pic tomorrow before starting
RT808 is offline
Old 05-04-2016, 08:57 AM
Scan it again for codes. A missing low resolution pulse signal from the Opti (bad Opti or bad wiring) should set DTC 16 when you try to start the engine.
Injuneer is online now
Old 05-16-2016, 07:11 PM
RT808's Avatar
i ran Scan9495 again, but no codes. i did not hook up the IAT since the intake and everything is in the house. rpm stays at 45 it is comm with PCM. i didnt crank 30 seconds, maybe 4 sec. Battery has not fallen below 68% since last attempt at codes. i charged it back to 100% before cranking.
should i start the harness checks? not sure where to start, i guess the opti harness. i want to put the water pump back on and refill with coolant as its been like that for 2 weeks.
RT808 is offline
Old 05-16-2016, 08:57 PM
45 RPM is typical reading before the PCM receives the pulse signals from the Opti. Try cranking for more than 4 seconds. Takes more than that for the code to set.
Rob/Shoebox asked if you have spark????
Shoebox has a guide to testing the wires for the Opti and the ICM.
Old 05-18-2016, 03:09 AM
RT808's Avatar
ok i'll read up on that and find my voltmeter
RT808 is offline
Thirim
07-30-2015 01:29 PM
browenb
07-19-2015 04:14 PM
surreybrad
05-31-2015 10:37 PM
Brett 91 RS LT1
03-12-2003 10:02 PM
gh0st
09-01-2002 10:24 AM
Quick Reply: in middle of opti swap, no start
