in middle of opti swap, no start
I just swapped my opti and wanted to see if it would start with just the harness and coil wire plugged in. cranks but does not start. not even a hint. battery at 100% on the charger last night.
is this normal? Should i put the wp back and everything? i disconnected battery. I did line up the spline on the opti correctly, i lined it up and after couple gentle pushes it pushed right in flush. bolted up also the opti i pulled spins freely and the rotor screws are tight. it was only a year old and clean inside. Have not scanned for codes since i tried couple months ago. i stupidly disconnected the battery to check wires before i got the cable and software. Car has been down for months after it stopped running on a city street. fuel pressure good and holds. |
Re: in middle of opti swap, no start
Are you getting any spark?
I know it isn't supposed to matter, but my car never wanted to start without the MAF plugged in. The IAT and coolant sensor might make a difference, too. |
ok thanks shoebox, i'll try it with MAF and IAT i also noticed that part of the harness that plugs into the opti on the intake. it come off a thicker bundle, but that part that hooks into the opti harness...it looks ratty. i'll take a pic tomorrow before starting
Scan it again for codes. A missing low resolution pulse signal from the Opti (bad Opti or bad wiring) should set DTC 16 when you try to start the engine.
i ran Scan9495 again, but no codes. i did not hook up the IAT since the intake and everything is in the house. rpm stays at 45 it is comm with PCM. i didnt crank 30 seconds, maybe 4 sec. Battery has not fallen below 68% since last attempt at codes. i charged it back to 100% before cranking.
should i start the harness checks? not sure where to start, i guess the opti harness. i want to put the water pump back on and refill with coolant as its been like that for 2 weeks. |
45 RPM is typical reading before the PCM receives the pulse signals from the Opti. Try cranking for more than 4 seconds. Takes more than that for the code to set.
Rob/Shoebox asked if you have spark???? Shoebox has a guide to testing the wires for the Opti and the ICM. |
ok i'll read up on that and find my voltmeter
