How can I drain my fuel tank?
A couple weeks ago I filled my tank up friday morning and blew the head gaskets slap out friday afternoon. My Camaro is dead, may it rest in peace. Now I have a full tank of gas that I need to retreve. How can I use the fuel pump on a 96 3.8 to get the gas out to put in my replacement vehicle?
Re: How can I drain my fuel tank?
Find whatever place on the fuel line that is convenient for you to open up and jumper 12v to the fuel pump prime connector in the RH shock tower area to run the pump and drain the fuel into a container.
Done and done. Thanx again shoebox for your help. Disconected the fuel lines at the injection system and hung them over the fender into a gas can then ran a wire with a gater clip from the battery to the prime conector. Maby you guys could make this a sticky. Any one doing this should of course follow all safty precautions and have a fire extinguisher on hand just incase.
2001CamaroGuy
04-05-2006 10:56 PM
guionM
9
08-29-2002 01:48 PM
guionM
18
07-11-2002 01:45 AM
