DRL Woes
Old Mar 25, 2003 | 05:56 PM
JediBandit's Avatar
DRL Woes
I did a search, but wasn't able to find anything that helped. My right turn signal doesn't work. When I hit the turn signal, it just stays on. The right front DRL/ turn signal bulb isn't lit up. Ok, no problem, right? So as I turn into my neighborhood to replace the bulb, it starts working again. I replaced the bulb anyways and it worked for 3 or 4 days. Now it is not working again. I don't know if it is something with the DRL or with the turn signal. Any ideas? Please tell me there was a TSB about this or something (since I see so many people driving around with a DRL out). Thanks. It is a 99 v6 m5, no mods.
Chris
Old Mar 26, 2003 | 10:12 AM
camaroEATSrice's Avatar
Cool
I built my own DRLs
Cool
I built my own DRLs
Old Mar 26, 2003 | 12:39 PM
JediBandit's Avatar
TTT Anyone?
Old Mar 26, 2003 | 02:47 PM
x7x7's Avatar
may be a problem with the bulb's socket or a loose ground. Most likely the socket, try cleaning it up with some contact cleaner and bend the contacts to make a better connection if possible.
Old Mar 26, 2003 | 03:03 PM
RallyRedTexan's Avatar
I found your post a little contradictory. Does your right DRL work? Does it just not blink for the turn signal function?
Old Mar 28, 2003 | 01:27 PM
JediBandit's Avatar
I'll try cleaning out the socket. Thanks for the tip.
The DRL does not come on, and it does not flash. Sorry if that was confusing.
Old Mar 29, 2003 | 03:37 AM
PaulN64's Avatar
anothing problem could be that the blub is loose and wasn't seated in properly. I did that when I replaced the blub one time and I thought that it had gone out. Just something to check.
Old Mar 29, 2003 | 03:50 PM
I would check it out with a new bulb just and see if it works. If a new bulb doesn't fix your problem then it's a wiring mess up somewhere.
Formula Steve
Sep 19, 2023 08:31 AM
ratio411
May 6, 2020 06:20 PM
blac94Z
Jan 16, 2015 11:03 PM
joshp14
Oct 23, 2004 12:17 AM
CJ Black LS1 Z28 M6
Middle Atlantic
Jun 15, 2002 10:12 PM
