Got the DRL's on and the Ram air intake installed...LOOK
Old Aug 4, 2003 | 11:21 PM
joshp14's Avatar
I bought the DRL's from www.webelectricproducts.com and got the GM ram air box brand new from a member of this site. Got the K&N too....pretty pricey though for that filter. I noticed a little performance gain with the ram air...and you can sure hear it hiss or suck the air when you nail it. I love the look of them both, what do you guys think?
DRL in light:
DRL in dusk:
DRL front shot:
Intake Before:
Intake After:
Hole cut with Dremel:
Old Aug 4, 2003 | 11:27 PM
bigdreamZ's Avatar
Wow great job on the intake, my lazy *** still hasn't made mine functional yet. I have all the pieces including the same intake as you from a WS6. Did you put any baffles or anything? I am wondering when I do this if I go to wash my car I am going to soak my air filter???
Old Aug 4, 2003 | 11:33 PM
joshp14's Avatar
Thats one thing I'm afraid of...is soaking the filter when washing with a power washer. It will only get wet if you spray directly into the nostrels. I think I'm going to all hand washes now. I'm going to get baffles for it, but they are like $65 each from GM ...I can wait on those. Bugs get into the filter really easy w/o the baffles...
Old Aug 5, 2003 | 10:49 AM
RS Dragster's Avatar
Looks really good man. I take it LT1's don't come stock with DRLs?
Old Aug 5, 2003 | 11:01 AM
pu12en12g's Avatar
The DRL's look good (I think they would look better hyperwhite)
The intake is a 100% improvement. WOW.
Old Aug 5, 2003 | 06:09 PM
joshp14's Avatar
I dont even think the DRL's was an option until 96 or 97.
I like the look of the amber DRL's better, but thanks for the compliment.
Old Aug 5, 2003 | 06:29 PM
xxsaint69x'sgirl's Avatar
where did u get the drls from?
Marcin
Old Aug 5, 2003 | 09:26 PM
joshp14's Avatar
Marcin
Read the first sentance in the first post.
Old Aug 6, 2003 | 05:38 PM
vandelay101's Avatar
josh...question about DRLs
Josh,
I saw the setup on www.webelectricproducts.com awhile ago but haven't heard of anyone using it untill now. I have one question for you. Some of the earlier DRL mods required replacing the stock turn signal flasher relay with a heavy duty digital flasher from autozone for around 10 bucks. Do you have any problem with the turn signals flashing with the webelectric kit, or did you have to replace the flasher.
Thanks,
Robert O.
Old Aug 6, 2003 | 06:17 PM
snorkelface's Avatar
DRL's weren't available until the '97 model year, and they are standard on all '97+ vehicles.
I like the look of the amber DRLs also.
Old Aug 6, 2003 | 06:34 PM
chasmanz28's Avatar
joshp how long did it take you to install the drl, was it easy to install
Old Aug 6, 2003 | 10:43 PM
joshp14's Avatar
Yes it was very easy, just kinda time consuming. The part that took the longest was running the wire from one side of the car to the other and then finding a place to give the module power. I have a wire running back to the fusebox...that way they turn on when my car does and I don't have to flip a switch or anything.
All-in-all it took me maybe 1.5 to 2 hours....but I'm a meticulous person and I like to take my time so I don't screw anything up.
Old Aug 6, 2003 | 10:52 PM
joshp14's Avatar
Re: josh...question about DRLs
Originally posted by vandelay101
Josh,
Thanks,
Robert O.
Nope...I haven't had any problems with it...it's a great module. Turn signals work just as they are supposed to. You can also choose the option of having a synchronized or non-sychronized mode on this module.
Old Aug 6, 2003 | 11:27 PM
ROADRAGE's Avatar
I am confused, why would you want to install drl's? They have a little **** on the dash to turn on the parking lamps.
My first mod was !drl's
Old Aug 7, 2003 | 01:16 AM
carlos64030's Avatar
Hey ROADRAGE...your car looks good with the shaved door handles! Is there a fail-safe mode for getting into your car in case the remotes or the door pop solenoid fails?
