LT4KM where can i get this and how do i instal it?
Old Mar 24, 2003 | 01:09 PM
bachehbad's Avatar
Ok i'm wondering what cars this comes from??? (the LT4KM that is) so i can call around junkyards to see if they have one. And also if i call a dealership to get the part what do i ask for??
The second part of my question is how hard is the install? I have a mechanic that does pretty cheap labour for me, would it be better to give to him or is it easy for me to do?
I have a catback exhaust, although i havent scanned for false knock (no scanner here) i'm hoping this will improve my top end a bit since right now it is very sluggish.
Old Mar 24, 2003 | 01:21 PM
teke184's Avatar
gm parts direct
about $35
pn: 16214681
it takes about 10 minutes to replace, just pull out the ecm unit from under the hood, remove two small torx screws and a metal plate, pull out the module, put in the new one and replace the plate and ecm...done...no mechanic needed...least i hope not
Old Mar 24, 2003 | 01:26 PM
GREGG 97Z's Avatar
I really doubt you need one with just a catback. Most people only get one after getting mods such as headers, rr's or cam and some will say it's not even necessary then.
Here is a guide if you have any other questions.
Old Mar 24, 2003 | 01:34 PM
bachehbad's Avatar
So am i just wasting my money??? because past around 5000RPM my power really isn't there.... i did some research and found a few people who bought the LT4KM got their top end power back by a little....
Old Mar 24, 2003 | 01:40 PM
teke184's Avatar
high rpm loss is more than likely something to do with the coil/coil wire or else a fuel supply problem..
spend the $35 on a msd coil from summit and check your coil wire...
Old Mar 24, 2003 | 01:42 PM
GREGG 97Z's Avatar
It won't hurt anything to install one but I doubt you will see any difference in performance with it. They are only supposed to help if you are getting false knock in the engine, I don't think the catback would be causing any.
Old Mar 24, 2003 | 01:43 PM
teke184's Avatar
wait a second....
do 93's even have knock modules...i honestly don't think so...guess that kindda anwwers the question.
again...look into the coil
Old Mar 24, 2003 | 01:52 PM
1997rblckSS's Avatar
93's don't have a Knock Module, the LT4 did not come out until 1996 in the Corvette Grand Sport. An LT4 Knock Module will not work in your car. OBDI? OBD2? to different PCMs.
Old Mar 24, 2003 | 02:34 PM
bachehbad's Avatar
Ok guys thanx alot for saving me the cash!
So my car won't have any knock retard ever right?? even if say i put 87 octance? isn't that bad for the engine!
Old Mar 24, 2003 | 02:40 PM
GREGG 97Z's Avatar
Originally posted by teke184
wait a second....
Doh!!! I didn't even notice he was a 93. You don't even have a PCM so no, there is no need (or way) to add an LT4KM
Old Mar 24, 2003 | 03:26 PM
You are confusing the knock module with the knock sensor. All LT1's have a knock sensor. Its mounted on the passenger side of the block, in the block drain hole. It "hears" knock, sends the signal to your ECM, and the ECM retards the timing. Same for all LT1's. If you use 87 octane, you WILL get knock retard.
The difference between the 93'a and all other LT1's is the fact it does not have a replaceable knock module. That is a small "filter" plugged into the PCM housing, that filters out the noise that was generated by the valve train (roller rockers) in the 96 Corvette LT4 engine.
Old Mar 24, 2003 | 03:27 PM
teke184's Avatar
i think they still have a knock sensor, but it's handled by the computer differently...
you'll have to contact someone a bit more knowledgeable than i on the 93 and obd1 computers..
i'd pm Shoebox with your problems/questions...he's a smart guy
Old Mar 24, 2003 | 03:32 PM
Injuneer definitely has it covered.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
FormulaV8
Sep 1, 2002 03:44 PM
