DS vibe?
Old Mar 22, 2003 | 10:49 PM
97 RedSS's Avatar
DS vibe?
After I swapped my Aluminum for a steel DS I have been getting some bad vibrations at 80+..When the DS was made they computer balanced it so I dont think its out of balance? Is there a certain torque spec I am supposed to tighten my U-Joints with on my Moser rear end? I just tighten them as fas as I can go..I even turned the DS 180 degrees and its still there..
Any thought/suggestions?
Cody
Old Mar 22, 2003 | 10:54 PM
Laymaster's Avatar
LT1 steel driveshafts are known to vibrate above 80mph...
You ditched an aluminum driveshaft and went with a standard LT1 driveshaft?
Old Mar 22, 2003 | 11:04 PM
RamAir95TA's Avatar
Steel is stronger than aluminum, and look what he has in front of it.
Old Mar 22, 2003 | 11:15 PM
97 RedSS's Avatar
hehe....yup I didnt want to twist the Aluminum shaft so I went with Steel..So your saying its normal for it to vibrate at 80? Wonder what causes it..It bugs me crazy when cruising on the interstate..
Cody
Old Mar 22, 2003 | 11:46 PM
96speed's Avatar
Cody
Cody: Its the driveshaft. After I swapped in that rear I had my u-joints replaced and the shaft rebalanced. After that I got a bad vibration from 70mph on up. Swapped in an LS1 driveshaft and it went away.
FYI: Before I grenaded my rear end my stock driveshaft never gave me any vibes, at all. From my experience, the stock driveshaft is hit or miss...
I'd get a Denny's or Mark Williams.
Ryan
Old Mar 23, 2003 | 01:18 AM
96z's Avatar
96z
Cody
You shouldnt be going above 80mph on the interstate anyway.
Old Mar 23, 2003 | 01:26 AM
Laymaster's Avatar
Unless you're in Montana!
Speed Limit : Reasonable LOL
warmeck
Jul 17, 2015 01:36 PM
dougg01
Dec 23, 2002 12:40 PM
Darth Xed
17
Dec 7, 2002 10:30 AM
floorpedal1
Oct 16, 2002 07:42 AM
