Cc305 Cam
The Hot Cam is cut at 112, thats why it sounds more "camier", both cams are about the same size. Last time I checked hot cams will pass with a tune, same with CC305, no tune both cams will run worse than stock and fail smog horribly. But theres always one person who begs to differ.
Specs
LT4 , 218 / 228, .525 / .525 112 LSA
CC305 220 / 230, .510 / .510 114 LSA
The CC305 is rated with 1.5 Rockers, I think with 1.6 I heard it comes out to the CC305 lifting .544 with 1.6s. The Hot cam is already rated at 1.6 for sure. I think the Cc305 will pass cut at a 112, just get that sucker tuned. Call Comp and tell then you want a CC305 cut at 112. They will do it for you.
I have been wanting to do a cam since I was like 6 before I knew what it even was, just liked that sound. Later found out it was a cam.
Specs
Combination motor sports will give you an actual kit for the cc305 cam. It is 580.00 plus shipping( about 10.00 ) and i hear it is worth the extra $$. This is what i plan to do this summer. I do have one question though, Will i need an air compressor to replace the springs in order to keep the valves from falling?? Thanks, Jason.
