Cc305 Cam
HEY,
I'm torn between the lt4 hotcam and the cc305. if i get a cc305 can i have cc grind the lsa to 112 instead of 114. what would i gain i that was done? thanks |
The Hot Cam is cut at 112, thats why it sounds more "camier", both cams are about the same size. Last time I checked hot cams will pass with a tune, same with CC305, no tune both cams will run worse than stock and fail smog horribly. But theres always one person who begs to differ.
Specs LT4 , 218 / 228, .525 / .525 112 LSA CC305 220 / 230, .510 / .510 114 LSA The CC305 is rated with 1.5 Rockers, I think with 1.6 I heard it comes out to the CC305 lifting .544 with 1.6s. The Hot cam is already rated at 1.6 for sure. I think the Cc305 will pass cut at a 112, just get that sucker tuned. Call Comp and tell then you want a CC305 cut at 112. They will do it for you. I have been wanting to do a cam since I was like 6 before I knew what it even was, just liked that sound. Later found out it was a cam. |
When I do my cam this summer, it will be a CC305 custom ground with a 112lsa and maybe a few more degrees of duration:)
Combination motor sports will give you an actual kit for the cc305 cam. It is 580.00 plus shipping( about 10.00 ) and i hear it is worth the extra $$. This is what i plan to do this summer. I do have one question though, Will i need an air compressor to replace the springs in order to keep the valves from falling?? Thanks, Jason.
try racenet.com my cam is very streetable after tunning i think it will pass we dont have that test here
Originally posted by smokindastangs Combination motor sports will give you an actual kit for the cc305 cam. It is 580.00 plus shipping( about 10.00 ) and i hear it is worth the extra $$. This is what i plan to do this summer. I do have one question though, Will i need an air compressor to replace the springs in order to keep the valves from falling?? Thanks, Jason. |
