Found your RPM stumble
Old Mar 19, 2003 | 04:59 PM
Wildwill532's Avatar
Its easy , last sunday in preparing to install longtubes I took off the AIR with a friend, and this morning I shut the car off at school and it was about 210 because i was sitting and i started it up again about 30 seconds later NEVER THE RPM UP OR DOWN went straight to 800 and stayed there i even tryed it after school it went straight to 800 while being hot. Hope this helps you all!
Old Mar 19, 2003 | 05:11 PM
Jcb890's Avatar
i'll second ASA's
jake
Old Mar 19, 2003 | 05:16 PM
n2ceptor's Avatar
also?????????
93Z Will
Old Mar 19, 2003 | 05:35 PM
ltlhomer's Avatar
Old Mar 19, 2003 | 05:36 PM
mineralwater's Avatar
I *think* he's trying to say that removing the AIR system got rid of his stumble.
If that's not it, i'll have to put in my vote with a as well.
Old Mar 19, 2003 | 05:57 PM
Originally posted by ACA Performance
How would !AIR cure a stumble though? Since its only on at startup
I don't know if this is his case, but for me, I had a crack on the AIR injection tubing - the one that goes into the manifold. I guess that could cause an exhaust leak, and mess up a/f ratios, cause false knock, all that good stuff..
but its still anyone's guess. For all I know, he could be saying he removed AIR and left it open and the car runs better now.. which might explain his post (exhaust fumes in cabin, anyone?)
Old Mar 19, 2003 | 08:57 PM
I removed the A I R injection from my car, this fixed the stumble
Old Mar 19, 2003 | 09:30 PM
Jcb890's Avatar
i'm not too mechanically enclined, so i dont exactly know what is meant by that, i wud like to know however....but i think that helped to clarify and will get rid of some of our s
jake
Old Mar 19, 2003 | 09:33 PM
Kreinmc's Avatar
What does going straight to 800 have to do with a stumble?
Old Mar 19, 2003 | 09:40 PM
ThotYouKnew's Avatar
Not sure if it deals with this but i noticed somethin the other day.
When i start my car up...the RPM's go up to 1500 and then drop and get kinda sticky at 1250 and then finally drop and stay at 1000...all takes like 2 seconds...is this normal?
Old Mar 19, 2003 | 09:42 PM
When my car is hot it will go from 1200 to 400 and up and down and sometimes die, but when i took the a.i.r off it wont do it anymore i tried all day
Old Mar 19, 2003 | 09:44 PM
and when i would drive before it would surge and it wont do it either i gave it so little gas just enough to keep accelerating
Old Mar 19, 2003 | 10:16 PM
NineSevenWS6's Avatar
My father mentioned this to me too. He has a 95 Imp, and he said it ran a while lot better after the !Air, possible coincidence I guess.
I think Ill try it when Im ready for that mail order tune....
Old Mar 19, 2003 | 10:29 PM
sounds good to me!
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
HuJass
18
Jun 24, 2002 09:19 PM
