Coolant Guage Sensor?
Old Mar 18, 2003 | 01:18 PM
ollie-99's Avatar
I did a cam header install and now my coolant temp is not reading on the guages
anyone gotta pick of where it is and how it looks??
Thanks!
-Oliver
Old Mar 18, 2003 | 01:27 PM
jonaddis84's Avatar
There are two. One on the water pump underneath it and the other on the driver side head, you might have messed up the one on the head while putting the headers on, or maybe the one on the water pump while doing the cam. Does it read spiratically, or never? When I first started mine up it wouldnt read for a minute then it would, you sure you bled the coolant system completely, if there are air pockets it could be reading the temp of the air in there.
Old Mar 18, 2003 | 01:31 PM
The dash gauge is fed by the sensor in the drivers side head, between Cyls #1 and #3.
Old Mar 18, 2003 | 01:33 PM
jonaddis84's Avatar
Learn something new everyday, thanks injuneer.
Old Mar 18, 2003 | 01:51 PM
ollie-99's Avatar
yeah the guages doesn't move @ all
anyone got a pic of what it looks like?
Old Mar 18, 2003 | 01:53 PM
ollie-99's Avatar
could this also cause my check engine light to come on?
Old Mar 18, 2003 | 01:59 PM
jonaddis84's Avatar
Is the low coolant light on? It could be causing the SES light to come on though.
Old Mar 18, 2003 | 02:00 PM
ollie-99's Avatar
actually it does come on once in a while then goes off
Old Mar 18, 2003 | 02:03 PM
jonaddis84's Avatar
I already asked this but you might not have seen it, are you sure you bled the system all the way, that could very well be your problem.
Old Mar 18, 2003 | 02:05 PM
ollie-99's Avatar
yep i bled the system
i was having problems w/ the low coolant light before too maybe thats just a bad sensor, but i never got the check engine light before when it came on
Old Mar 18, 2003 | 02:10 PM
jonaddis84's Avatar
Id replace that sensor on the head, its right above the plugs on the driver head, inbetween 1 and 3. It shouldnt be too expensive, check out shoeboxes part # and price list
Old Mar 18, 2003 | 03:43 PM
The low coolant switch is only wired to the idiot light on the dash, not through the PCM. No SES light for "low coolant".
warmeck
Apr 27, 2015 04:34 PM
phoenix95
Jan 8, 2015 02:44 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
91Bird305
Aug 8, 2002 12:36 AM
JurisAg02
Jul 27, 2002 11:49 AM
