howmany of you removed your rad to change the opti?
Old Mar 18, 2003 | 09:35 AM
94Zpower's Avatar
I am about start my opti swap an dwas wondering who has removed the rad to free up some space? if so what about the A/C pipes & hoses? wouldn't the system loose pressure and empty out?
Thanks for the help!
Gary
Old Mar 18, 2003 | 09:37 AM
Xscream's Avatar
I do, makes it a hell of a lot easier... I dont' have AC and its a stick so that helps with the removal.
Old Mar 18, 2003 | 09:42 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I changed my opti in my driveway and i didnt take out the radiator. You definately need to take out the fan shroud though (sp?). That frees up enough room to work. Drain all of your coolant out too. I think that SHOEBOX has a "how to" change your opti on his tech page. Hope this helps and good luck changing the opti. Remember to line it up CORRECTLY!! i didnt the first time and had to rip everything back off to fix it!!! Later
Chris
Old Mar 18, 2003 | 09:54 AM
94Zpower's Avatar
Thanks guy's!,
95-Z28quicksilver
do you have a link for shoeboxes site?
Old Mar 18, 2003 | 09:57 AM
95 Z/28 LT1's Avatar
Super Moderator
I had to pull one of the elecric fans off because the puller i used to take off the balancer wouldn't fit otherwise.
Old Mar 18, 2003 | 09:59 AM
anaik's Avatar
Originally posted by 94Zpower
Thanks guy's!,
95-Z28quicksilver
Here you go.
http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html
Old Mar 18, 2003 | 10:23 AM
94Zpower's Avatar
thanks guy's!
Old Mar 18, 2003 | 10:54 AM
93Z286Speed's Avatar
im doin mine in 2 weeks
Old Mar 18, 2003 | 10:56 AM
Javier97Z28's Avatar
Moderator
there's no need to take off the radiator.. that's over complicating it....
Old Mar 18, 2003 | 11:02 AM
97FormulaWS-6's Avatar
I never took the radiator out... the Fans have to come out because of the puller for the hub, but other than that it's an easy job, took me just over 2 hours from start to finish and that was doing it twice because I didn't get it on right the first time.
Old Mar 18, 2003 | 11:08 AM
I don't have an opti change out page but there is one here.
I did not remove the radiator and had plenty of room. I did take the fans out, but you could even do it with them in.
Old Mar 18, 2003 | 11:31 AM
interesting... i had madwolf helping me do mine, so im sure he knows what to do
Old Mar 18, 2003 | 12:35 PM
Don 97 SS's Avatar
Leave the rad in but just unhook two of the tabs on the fan wiring harness (that holds the harness to the housing) and then drop the entire fan/housing down and out. I can do this without any tools, although a small flat blade screw driver helps pop the wiring harness retaining tabs loose without damaging them!
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Mar 18, 2015 01:25 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
pologreen97z
Dec 2, 2014 10:42 AM
