more ? about engine components
Old Mar 11, 2003 | 08:22 PM
glennxx1's Avatar
...any piston will work? any piston, if its same size sleeve n all, not bored i can use any piston?, and i cant seem to find bottom end rebuild kits any where that are anything but stock replacements
Old Mar 11, 2003 | 08:29 PM
badass383's Avatar
Not sure what your question is but no not any piston will do. You have compression ratio to worry about. Valve clearance to worry about. The list goes on and on.
Let's hear the question so we can help.
Old Mar 11, 2003 | 08:37 PM
glennxx1's Avatar
well i cant seem to find a place i can get a kit for, just like....for a FULL top & bottom end rebuild, i want my ,every day car, lt1 6 speed to run high 10's low 11's w/o nitrous and w/o a huge gear in the rear, i want a heads/cam package BUT also want to replace pistons, rods, dont no what heads to go with, but new set of heads, basicly rebuild motor completely to run high 10's low 11's and be every day driveable
Old Mar 11, 2003 | 08:59 PM
glennxx1's Avatar
valve clearence? if i get roller rockers and low comp pistons, a real strong cam, like .510 int lift 540 exh. , what does the stock LT1 crank break at (HP range)? what about the rods?
Old Mar 11, 2003 | 09:30 PM
CamaroBoy96Z28's Avatar
500+ rwhp is where the stock nodular iron crank starts to take a crap. Not sure about the rods, someones got to know.
Old Mar 12, 2003 | 05:29 AM
badass383's Avatar
Not sure about your expertise but I suggest you contact a few engine builders like scoggin-dickey, TPIS or best of all Nick Norris at Nu-Tek Motorsports. This guy eats sleeps and drinks LT1's. He can provide you with anything you need from parts to a crate engine. try calling 866-77nutek or on line at www.nu-tekmotorsports.com
As far as valve clearance is concerned, that depends on crank throw, rod length, piston compression height, cam lift to mention a few.
Just to give you an idea I have a 3.75 stroke with 6" rods. I wanted about 1 tick lower in compression (about 9.4:1) and high lift (0.563) so my pistons are -24cc dish type.
These guys can help you talk to them. After that read, read, read.
DirtyDaveW
Dec 1, 2016 05:37 PM
CARiD
Jan 27, 2015 06:27 AM
97z28k&N
Jan 9, 2015 04:58 AM
guionM
69
Nov 30, 2006 02:01 PM
