Do you need to degree the LT4 hotcam
Old Feb 28, 2003 | 09:51 AM
Blk94Z28LT1's Avatar
Just bought the LT4 hotcam kit, Does this cam need to be degree'd. This is the first time i have installed a cam into a LT1 engine. I've done alot of other smallblocks!
thanks
Old Feb 28, 2003 | 09:55 AM
Rodrigues's Avatar
You just need to line up the dots on the timing sprockets when you put on the chain...
Old Feb 28, 2003 | 10:32 AM
anaik's Avatar
Re: Do you need to degree the LT4 hotcam
thanks
You can degree it to see if the cam is equal to the given specs on the card. It can only be installed with the dots lined up, otherwise it will throw the opti off.
Old Feb 28, 2003 | 12:18 PM
BAD 97 WS-6's Avatar
Mine is degreed 2.5 points.
Done by an old school engine builder that built well over 2500 engines in his life time. Computer tuning makes everything run perfect.
Old Mar 1, 2003 | 07:45 PM
arnie's Avatar
Re: Re: Do you need to degree the LT4 hotcam
If you think about that for a minute, you will find that the opti signal is driven from the the cam (cam itself). If the cam is 'off' in relation to the crank, which btw, is the reason you 'degree' a cam, (to have the cam in sync with the crank) the opti signal will also be off (not in sync) in relation to the crank. Go ahead and degree the cam.
(Deleted portion of post 12-30-03)
Old Mar 1, 2003 | 10:35 PM
Prorac1's Avatar
Just my .02 cents but, the actual definition of degreeing a cam is to varify the intake and exhaust opening and closing points, not to nescesarilly change anything. But if (on an older small block) you were going to advance or retard the cam install, this would be the time that you would do it. Prorac1
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
13qtr
Jul 19, 2015 05:30 PM
