low resolution failure
Old Feb 27, 2003 | 03:36 PM
kindaslo's Avatar
I installed a digital 6 plus msd box on my car and now when i turn the data logger on it says there is a low resolution failure....any help would be appreciated
Old Feb 27, 2003 | 03:45 PM
Can we assume your car is OBD-I and you are getting DTC 16, for low resolution pulse not detected? Is the engine running? If the engine runs, you have a "stored" code, since the engine can not run if DTC 16 is an "active" code. Lacking the low res pulse, the PCM shuts down the injectors and fuel pump.
It is not unusual to see an intermittent DTC 16 stored... sometimes happens when the PCM can't find the pulse immediately on startup. Did this code only show up after the MSD install?
Old Feb 27, 2003 | 03:46 PM
94SLUG's Avatar
Low res is an opti code #16. I get this code now and again(1 time every month) even though i put 3 optis in trying to get rid of it. If it runs good and no timing is getten pulled leave it. I reset the ecm to get rid of code.
Old Feb 27, 2003 | 03:58 PM
kindaslo's Avatar
Thanks for your guys help...it defintely is a stored code...il erase it and see if it comes back....
Ericksd
Jan 20, 2016 06:07 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
KYWes
Sep 26, 2015 08:49 AM
jackpawt883
Sep 10, 2015 08:53 PM
