Egr Pipe Or Solenoid
Old Feb 24, 2003 | 10:44 PM
Wildwill532's Avatar
Is it the EGR pipe or the EGR soleniod that comes off to block Im glad I cought this before I took one off!
Old Feb 24, 2003 | 11:07 PM
Old Feb 24, 2003 | 11:08 PM
qwick_trip's Avatar
what do you mean by egr solenoid
Old Feb 24, 2003 | 11:24 PM
I don't fully understand your question the way it is worded.
There is an EGR pipe, EGR valve and EGR solenoid.
Old Feb 25, 2003 | 12:09 AM
cals400ex's Avatar
when we block off the egr system do we block off the valve and the pipe? i was just wondering because tpis sells two different blockoff plates for the lt1. thanks
Old Feb 25, 2003 | 12:56 AM
Blocking off the valve (bigger plate) effectively ceases EGR function. You can leave the EGR pipe as it is, but hot exhaust gases will still be brought to the intake manifold (they just won't go anywhere). If you block the pipe, too, you will stop the exhaust from coming in. You could then remove the EGR pipe from both manifolds and block the exhaust manifold side with something suitable. This will get the heat away from the back of the intake manifold that some people believe helps to cause the infamous rear manifold oil leak.
Old Feb 25, 2003 | 03:03 PM
I meant the big black EGR valve that whole black thing sorry not the solenoid, so does the WHOLE EGR VALVE come off or the EGR PIPE to Ehaust Manifold?
Old Feb 25, 2003 | 03:24 PM
You can effectively eliminate the EGR system function by blocking off exhaust flow through the corrugated tube from the #8 exhaust runner to the back of the intake manifold. Cut a diamopnd shaped blocking plate out of sheet metal, put two holes in it to fit over the two studs in the manifold, and sandwich the plate between the tube and the manifold. That way, you don't have to do anything else.
If you wanted to remove the system completely, you block both the hole where the tube from the exhaust connects, and the hole where the big black EGR valve sits. But then you will also have to block the connection on the #8 exhaust runner, and plug up the vacuum line from the EGR solenoid.
What exactly are you trying to accomplish?
Old Feb 25, 2003 | 03:30 PM
Fred/Injuneer proves that there is more than one way to eliminate the function of the EGR.
Your goal will determine what method you choose.
Old Feb 25, 2003 | 03:32 PM
qwick_trip's Avatar
is the egr solenoid the circulair piece on the back of the intake with two small lines running out of it? if so how how i eliminate it do i just take it off and plug the holes??
Old Feb 25, 2003 | 03:50 PM
Did you look at the pic link above?
The round EGR valve only has one vacuum line. The solenoid has a vacuum feed from the intake manifold and a line going to the EGR valve to operate it.
Another question would be why you want to remove it? There is no performance gain by removing it.
Since this seems to be the thread for different ways to stop the function of the EGR valve, another way is merely to remove the EGR vacuum feed hose from the manifold nipple and put a cap on the nipple. If the solenoid gets no vacuum, it cannot open the valve. As long as the valve is sealing well, it is as effective as a block off plate, but you don't even have to touch it.
Old Feb 25, 2003 | 08:03 PM
cals400ex's Avatar
i was told by removing the egr system your car would run at cooler temperatures. i don't know if this is true or not. i think i want to remove the egr pipe as well. i wasn't aware of the egr pipe going to both manifolds. anyone know what we can block the exhaust manifold side with? thanks
Old Feb 25, 2003 | 10:35 PM
I am still not sure if it is the EGR METAL PIPE THAT GO'S TO THE MANIFOLD that comes off does all the **** back there come off and get block lol these are hard to understand
14
Aug 11, 2015 12:03 PM
4586
Jul 31, 2015 06:03 PM
Jlo
Jul 29, 2015 03:52 PM
alphaauto
Jul 26, 2015 04:40 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
