Speed density and supercharging...
Old Feb 23, 2003 | 06:56 PM
Highlander's Avatar
Is it tuneable and safe?
I was considering going speed density Thanks
Old Feb 23, 2003 | 11:19 PM
Alvin@pcmforless.com's Avatar
If you can use an aftermarket PCM with 2bar capabilties yes it is safe.
If you can get a crank trigger on the car and use a 7749 PCM you could do it as well.
Other wize, stock 93 pcm in my opionion you MUST run a FMU for driveablity etc... see the post FMU Deletion or something along those lines
Old Feb 23, 2003 | 11:36 PM
Bryan 94 Z28's Avatar
With my limited and minimal knowledge on the subject of tuning, I believe I saw that you can disable the use of the MAF sensor with LT1_edit and force the PCM to run using speed density.
I've also heard that tuning for speed density is much more difficult than when using the MAF.
Old Feb 23, 2003 | 11:41 PM
Its not so bad, if you get the hang of it you'll be surpised how easy and straight forward it is
I love speed density!
Old Feb 24, 2003 | 10:41 AM
brand-x's Avatar
I run a accell gen vii in speed density mode...I picked up 2-3 psi of boost from deleting my maf meter and the car idles better (no more surge).
DirtyDaveW
Dec 1, 2016 05:37 PM
May 8, 2015 11:30 AM
3TAS4ME
Apr 15, 2015 02:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jul 4, 2005 05:00 PM
