ProCharger or Vortech?
Old Feb 22, 2003 | 06:18 PM
GreaseMonkey83's Avatar
which supercharger would you choose if you had to pick between a vortech v-1 t-trim or a procharger p-1sc? and do any of you know the pressure ratio of either of them?
Old Feb 22, 2003 | 06:34 PM
engineermike's Avatar
If you ask 10 people this question, you'll get 5 Vortech votes and 5 Procharger votes.
I prefer Vortech because the impeller shape seems to be more up-to-date and the fastest LT-1's use Vortech's.
Mike
Old Feb 22, 2003 | 06:45 PM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
Procharger, on order.
Brandy's Avatar
Less problems with the Vortech's leaking and I've yet to see one have an internal bearing failure. They are way behind the times in max all out power blowers but for a street car they still are the best IMO.
Old Feb 22, 2003 | 06:47 PM
rskrause's Avatar
Moderator
I had a Vortech S-trim, which gave yeoman service. When it came time to upgade, I chose the Procharger F1 as it'a about the same size as the T-trim but flows more air. Both are good compressors.
Rich Krause
Old Feb 23, 2003 | 08:14 AM
MEAN LT1's Avatar
Ahh....the age old question.....Im a procharger guy just for the simple fact the Ati's blower comes with an intercooler as supposed to vortech which has there after cooler as an option.
Old Feb 24, 2003 | 01:26 PM
9SECONDLX's Avatar
it also makes a difference if your car is stock or not.
if your car is stock a t trim is way to much blower for a stock lt1. i have a t trim on my mustang and its great on a mustang. (lower comp. motor)
for a camaro i went with a procharger because of the inner cooler and higher compresion of the motor at the time when my car was stock.
a p600b is good for a stock motor. you can buy used ones from 1500-1800 with an inner cooler.
if you plan on building a race motor or stroker then its a whole new stategy. at least a t trim or d1.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
95blkss
Sep 22, 2015 03:18 PM
95blkss
Jul 13, 2015 01:28 PM
