Lou's Short Stick!! Good or NOT?
Old Feb 18, 2003 | 05:30 PM
StylezZ28's Avatar
I was lookin into Lou's Short stick... well actually i am i am lookin for mods that don't void warrenty O_o. Anyway i saw pics of it and I love the shorter handle, but how does it work for u guys? Does it decrease the throw? What are ur opinions on it?!?!
Old Feb 18, 2003 | 06:41 PM
stik6shift93's Avatar
It shouldn't void your warranty, it will give you shorter throws. On my 5.0 there was already and extra inch or so of threads, I basically just cut them off and it worked great. BTW I'm not sure if you can do this with a stock one, my hurst **** only uses about 7 threads so I could cut of a lot without a problem.
Old Feb 18, 2003 | 06:53 PM
Michael4034's Avatar
I've got a 2001 & i love the short stick. Not only does it shorten throws but it also gives you a more positive feel when going through the gears. Takes about 30 min to install.
Old Feb 18, 2003 | 07:24 PM
blacknight's Avatar
It's not good or bad, IT'S GREAT.
Old Feb 18, 2003 | 07:41 PM
02CamaroZ28's Avatar
Def a real nice mod. I absolutely love it on top of the stock hurst. It is angled and i installed it with the angle facing the front of the car so when in 2nd, 4th and 6th it wouldnt be to close to the rear console. Also it gives a better feel for the shifts since the rubber in the stock shifter is gone, makes a nice click as you shift also
Mark
Old Feb 18, 2003 | 07:52 PM
Booradley's Avatar
Check out the Qwik Stick. It's the same idea, about 2 inches shorter than the stock unit and it doesn't have the rubber in it either. It's different than Lou's in that it's chrome moly, not bent and it's $10 less. Speed Inc. and LM Performance sell them. it works awesome.
www.lmperformance.com
www.ls1speed.com
Old Feb 18, 2003 | 10:41 PM
StylezZ28's Avatar
www.ls1speed.com
Is chrome Moly stronger then steel? cuz the boot is gonna cover everything anyway so looks don't bother me. Thanks all for ur input i am def buying it along with clear corners from Afterthought.
Old Feb 19, 2003 | 12:58 AM
Blue89Bird's Avatar
get one, they're the ish
Old Feb 19, 2003 | 09:37 AM
rncotton's Avatar
I've got the short stick from Spectacle Solutions on my car. www.spectaclesolutions.com
$28 I think
Old Feb 19, 2003 | 03:34 PM
Teal94Z's Avatar
There is a guy on ebay that sells them for $20, they are machined, and chrome, I have one, and its awesome!
slocody
Feb 10, 2003 01:04 PM
GRN96WS6
Sep 8, 2002 10:45 PM
slothgrant
Aug 22, 2002 03:01 PM
jim88iroc305
Aug 13, 2002 09:24 PM
kurob25
Aug 5, 2002 08:03 PM
