new pcm/ base program ?
Old Feb 14, 2003 | 09:40 PM
396jon's Avatar
What is the best ay to get a new pcm flashed with the base program....
I mean the new dealer,kragen,napa pcms are totally blank right? The car will not run on one correct? because the base power train program doesn t exist? Or can I expect them to come with a usable program that I can reflash with tuner cat....
All this cause I need a few obd1 pcms ........need one soon.....so if you have one let me know how much.....
I have cores if your at the dealer too.....
Old Feb 18, 2003 | 01:22 PM
Monodax's Avatar
The only way to get a program into the blank computer is to take it to a dealer with a Tech-II. They have to plug into the diagnostic port and put a base program in that way. I had to borrow my friends lt-1 transam and take it to the dealer then we swapped the computer out and programmed it that way. This was before I bought my eeprom burner and socketted my computer. Tunercat or LT1 Edit require the base program in order to get the communications going to reprogram it.
Old Feb 18, 2003 | 05:42 PM
madwolf's Avatar
What happened to your old pcms/cores? I might be able to help with those depending on what happened to them, but I can definetely help you with uploading the right program in your new ones.
Old Feb 18, 2003 | 05:45 PM
madwolf's Avatar
Ooops, I'm sorry Jon. I just noticed that I forgot to reply to your email. What we spoke of last time is still available if you're interested....
Old Feb 18, 2003 | 09:24 PM
396jon's Avatar
I m not sure I know forsure what your rferring too.....sort of just guessing I didn t receive something....?
I still have two obd 2 cores....and one obd 1 core....the obd2's are fine......the obd1 is smoked.....
I still need two more obd 1's.......one is on the way.....that will atleast get me by.....
Old Feb 19, 2003 | 05:41 AM
madwolf's Avatar
You wrote me about an OBDI a few days ago... You probably forgot already.
Anyway, what happened to the "smoked" OBDI? How did it die?
G-BODYT56
Jan 14, 2022 11:14 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
surreybrad
Sep 29, 2015 09:00 PM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
