Traction Control Logic Module
Old Feb 11, 2003 | 10:09 AM
Jack&Dee's Avatar
Well, I was hoping to get one of these to turn off the traction control in my 02, but after reading this I am a bit annoyed..
SLP Traction Control Logic Module, 1999-2001 F-body (will not work on 2002 models)
Does this mean all brands will not work on a 02 or just SLP's model? If it doesn't, there is no way to turn it off?
Old Feb 11, 2003 | 09:23 PM
stik6shift98's Avatar
dont u have s switch to turn it off.....its the asr button if thats what your looking for???
Old Feb 12, 2003 | 06:18 AM
Jack&Dee's Avatar
Post
Bro, if I had the switch i wouldn't be lookin for one My car came pretty plain other then t-tops. Guess maybe I need to move to the advanced forum??
Old Feb 12, 2003 | 06:58 AM
PhantomTA's Avatar
Moderator
if you dont have the switch to tturn it off.. you dont have it..
lol
the logic modual plugs into switch so when you start the car it defaults the traction conttrol to the off posistion.
it wont do you any good if you dont have the switch, cause you dont have traction control
Old Feb 12, 2003 | 08:27 AM
lol
i was thinking the same thing.....im like doesnt that thing just turn traction off when u start the car instead of leaving it on so i have to turn it off all the time.........
traction control
i did save my a$$ a couple times in the rain with the nittos tho
Old Feb 12, 2003 | 08:40 AM
PhantomTA's Avatar
Moderator
yeah driving with 315 nittos it saved me twice from possibly being in a bad situation in the rain and a few times in the snow with comp ta's
Old Feb 12, 2003 | 08:47 AM
ya i had to drive it in the snow with them about 2 weeks ago....
there was a hil and it took me 25 mins to get up in 5th gear goin 2mph sideways.....normally it stays inside when it rains or snows
it sucked big time
Old Feb 12, 2003 | 09:10 PM
Jack&Dee's Avatar
Ok I am pretty sure... that when you spin the tires and the engine bogs and the little light that says traction lights up, you have traction control..... Maybe wrong here but it seems a pretty solid guess. Yes, I understand now the module plugs into the switch on the 99-01 and several sites have them listed as 02 as well. I have called the companies that offer them and have gotten a yes it will work, and a no it won't. The no's where the same case you have stated and the yes's where the box says...
So I am back to the original question. Are the switches different, or maybe the wires are back there and it installs differently. Anyone have a 02 that has seen this?
Old Feb 12, 2003 | 09:31 PM
stik6shift93's Avatar
Has anyone developed a way to delete this yet, this girls has that on her 02 and it totally kills your launches.
Old Feb 12, 2003 | 09:47 PM
the pool boy's Avatar
um, my t/a has TCS, and i push the button that says "TCS" in front of my shifter to turn it off - am i missing something?
Old Feb 12, 2003 | 09:53 PM
Jack&Dee's Avatar
Hmm maybe just everything posted above yours
So at least I am not crazy or stupid... Well at least not on this one... Glad to see at least some one has seen it on a 02.
Old Feb 12, 2003 | 10:14 PM
sorry, i'm a bit confused - do you or do you not have a TCS (traction control) button? i was under the assumption that if your car were equipped with traction control, you would have this button. if you do have the button, then i have not heard any bad press on any other company's logic modules (which simply turn TCS off when you start the car instead of you having to turn it off manually, i.e. the button). if you don't have the TCS button, then i'm dumb b/c i thought any 4th gen with traction control has the button.
Old Feb 12, 2003 | 10:36 PM
the guy doesnt have it......
Old Feb 12, 2003 | 11:03 PM
Jack&Dee's Avatar
WOW your right!!
I figured out the light on the dash was god ****ing around with me and the bog down was the alignment of the stars causing a solar flare in the sun effecting the gravitational pull of the earth directly around my car!
If anyone can help, please do so. If you just want to argue about what is on my car then just please say it to yourself and save me from having to read it......
Old Feb 12, 2003 | 11:24 PM
Originally posted by Jack&Dee
WOW your right!!
the guy above my post was confused... i was just answer his question....
chill man...
