how to tighten fan belt???
Old Feb 9, 2003 | 07:33 PM
97droptopZ's Avatar
anybody know?
got an annoying loud squeaking noise from when i start my car to when i turn it off... makes me embarrased cuz people might think i got a POS but they just dont know bout the power...
Old Feb 9, 2003 | 07:41 PM
95loveaffair's Avatar
The "fan belt" is a serpantine design. Tension is held on the belt automatically via the belt tensioner. If the belt becomes too warn out then you just replace it. Signs of wear are glazing, more than three crack across in a one inch section, and the tensioner indicating it's out of limits. Cracking is normal but it just shouldn't have three straight across in a one inch span.
Old Feb 9, 2003 | 08:12 PM
SnkEatr's Avatar
Its replace the belt time, mine did the same thing, squealed like a little pig, until i stuck a new belt on. Cheap part, hard as hell to put on flying solo. Get some help. to hold it in place while you work from underneath on the tensioner.
Old Feb 9, 2003 | 08:23 PM
97droptopZ's Avatar
sounds like a plan... ill go by autozone tomorrow and see if they have the belt and maybe get my SES light scanned if they still offer that
thanks a bunch
anybody have tips on installing it, im not the best w/ engines
Old Feb 9, 2003 | 08:50 PM
Projectz28's Avatar
Moderator
Most likely just te belt. To remove it you need a 3/8" ratchet.I belive its a 13mm nut on the tensioner... (correct me if I am wrong) use that to pull the tensioner loose, then the belt will slid out. Just take notice as to how it was routed. Put the new belt in its place and use pull the tensioner again, sliding the new belt back on. thats it. But before you buy the belt, just check the tensioner. Pull the belt off and make sure you dont have anything locking up on ya like an alternator or something. if a bearing on an accessory is going south on ya it will produce the same sound. The tensioners on the LT1's were/are not the best of quality and have been known to break. The belt is not a hard job, but it does help to have an extra set of hands to hold the tensioner while you change the belt.
Magenta_Hearts
Mar 29, 2017 08:54 PM
sseeya
Apr 9, 2015 06:38 AM
94 green drop top
Aug 8, 2002 04:11 PM
JDohn2001
Jul 26, 2002 05:57 PM
JDohn2001
Jul 26, 2002 08:14 AM
