Too small cam wants to be retarded, and too big advanced - right?
Old Feb 9, 2003 | 05:09 PM
LTOne4Fun's Avatar
If you had an undercammed motor, it would pick up power be retarding the cam a few degrees right? besically delaying the intkae closing point, putting it where it would be with a bigger cam. This would aslo drop the dynamic compression ratio correct?
Old Feb 9, 2003 | 05:18 PM
Josh-'04 GTO's Avatar
Retarding the cam will shift the powerband upward and reduce low end torque, while advancing the cam will bring the powerband lower.
Old Feb 10, 2003 | 12:36 AM
SStrokerAce's Avatar
Your right on what you said.
It's funny that a stock LS1 cam is retarded a few degrees stock and it has a very high LSA like 116-117.
The right cam IMHO will be straight up.
Bret
Old Feb 10, 2003 | 03:03 PM
rskrause's Avatar
Moderator
My 214/224 XE cam is ground (and installed) "straight up" and works well.
Rich Krause
rideordie
Nov 5, 2019 04:52 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Noenav
Dec 6, 2014 07:35 PM
