Car is idling at 2000rpms
Old Feb 3, 2003 | 11:33 PM
Formulized94's Avatar
Anyone know why my car could be idling between 1700 and 200 rpms. Just got it back running. Didnt have it apart just changed cars and used the same engine. Any help on this matter is appreciated. My mods are in my sig.
Old Feb 3, 2003 | 11:36 PM
Did you check the throttle cable to make sure it wasn't holding the blades open?
Did you check to make sure all the vacuum lines are hooked up to the intake manifold?
Old Feb 3, 2003 | 11:55 PM
yes all the vacuum ports are plugged off or used..... and the trottle cable is fine
Old Feb 3, 2003 | 11:56 PM
Fatdog's Avatar
Cool
I changed my gas filter,and this fixed a surging I had at stop lights ,or going through Del Taco lines.And I changed this beast only 1 1/2 years ago .Hope this helps.(These darn fram filters are a piece of work).My02
Old Feb 4, 2003 | 12:41 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
wouldn't that be an opti problem? but damn man... 1700 idle... that must be a killer help at the track =] not too conveniant at stop lights tho...
Old Feb 4, 2003 | 01:00 AM
neil350's Avatar
Check those sensors on the throttle body, after i did some thing i forgot to plug one back in. The car would idle at 1700.
Noenav
Mar 1, 2019 07:38 AM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
