4L60-E Help!!!!
Old Feb 1, 2003 | 12:55 PM
TechCam97's Avatar
Question 4L60-E Help!!!!
Hey everyone, I had a quick question about my friends 4L60-E. He's got a 1994 Trans Am Automatic that's shifter reads (In order from top to bottom): P R N D 3 2 But no 1. So I took off the upper shifter plate and cut out the plastic stopper but it still won't shift down to first. I was told on this board that all you'd need to do is cut out the stopper and it should go. What should I do? Can I fix it to go into first? Thanks in advance,
Old Feb 1, 2003 | 02:16 PM
If the shifter will actually travel farther back than it used to, it should go into 1st gear, unless maybe the cable is not adjusted properly.
Old Feb 1, 2003 | 04:46 PM
TechCam97's Avatar
Well, the shifter won't go into first at all. You know if you look at the shifter there is a little wheel connected to the bottom? The wheel rides in the little grooves of the gear. When trying to shift from 2 down to 1 the wheel rolls up towards the hump in the gear but won't go down the other side to go into first. It stops in second. Is there something I can readjust? Or do I have to do the way that you showed me above. Thanks
Old Feb 1, 2003 | 06:35 PM
94SLUG's Avatar
Can i ask why? There is no point in doing this. It tends to be hard on the tranny. ITS NOT A TH350, there is a lot of electronics in a 4l60e. Just floor the damn car, and or change shift points.
Old Feb 1, 2003 | 06:39 PM
TechCam97's Avatar
I don't know why my friend wants it done, he just does. So since I'm the most mechanically oriented of our group, I decided to give it a whack......
Old Feb 1, 2003 | 06:43 PM
funina91ss's Avatar
I just did mine last night had the shifter cover off anyway so just went ahead and done it.. just make sure you have the block cut off flush with the shifter mech... but if I am racing I always leave it in OD.... I just wish my car had 2nd gear start so I could take off from a stop..
Old Feb 2, 2003 | 09:12 AM
kjlvilla's Avatar
You will not be able to go to L1 with this shifter. If the car was manufactured with the lower gear ratio offered for that year, I think it was a 2.73 or somewhere around there, GM shifters will only go to D2. The reason for this is the vehicle would exceed acceptable government sound limits if driven in L1. So I'm told by G.M. All you need is a shifter with a L1 position, the valve body is the same in all the f-bodies. This is a good way to determine which gears a car has when shopping. Look for the L1 quadrant for 3:23s. Hope this helps.
Old Feb 2, 2003 | 10:03 AM
There is no difference in the shifter or tranny (except for the tab). All you have to do is remove the tab like you did. If it won't pull all the way down to 1, then adjust the cable like I described. It should work fine. Tons of people have done this, so I know it works.
Daniel6718
Parts Wanted
May 26, 2007 08:14 PM
Daniel6718
West South Central
May 25, 2007 06:58 PM
dhirocz
Oct 23, 2006 08:16 PM
texasTA
Apr 8, 2005 04:38 PM
95LT1Z28
Feb 16, 2004 09:05 AM
