changing tranny fluid
Old Jan 26, 2003 | 03:51 PM
joed4640's Avatar
im overdue on a fluid change a few questions
is there a plug simular to the oilpan? do i need to replace the filter?
anyone used trick shift additive?
Old Jan 26, 2003 | 04:08 PM
CODY BEHNKE's Avatar
Just drop the pan, You can add a aftermarket drain plug but unless it is a weld in unit they can leak.
Just use strait certified transmission fluid.
Old Jan 26, 2003 | 09:29 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
yeah drop the pan, make sure you have a few rags , and a big bucket , its nasty sheet...., and yes replace the filter when you put the new fluid in
Old Jan 27, 2003 | 02:38 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
there was a post just yesterday on this
with 20 superflous replies
do a search
use ford fluid
Old Jan 29, 2003 | 12:34 PM
Ford fluid is another stupid thing to do even dumber than additives.
Old Jan 29, 2003 | 01:01 PM
treyZ28's Avatar
Gm drivetrain enigeer/ 4L60E developer/ tester > Cody
care to explain your position?
Old Jan 29, 2003 | 01:47 PM
V6 Punk 93's Avatar
PCLZ28
Dec 24, 2015 05:19 PM
jmadoll
May 27, 2015 07:13 PM
VF-124
Mar 16, 2015 08:14 PM
mattszm6
Dec 14, 2014 07:09 AM
