A.i.r ??
Old Jan 26, 2003 | 04:15 AM
tireburnin's Avatar
A.i.r ??
I am looking at purchasing a camaro that had the AIR system removed. I need to have that installed to pass smog in my area.
What all was done in the !AIR mod?
What do I need to do to fix it and pass smog?
Thanks,
Sean
Old Jan 26, 2003 | 01:39 PM
tireburnin's Avatar
Anyone ???
We CA people don't know about this lack of smog equipment stuff
-Sean
Old Jan 26, 2003 | 01:47 PM
The AIR system is not the same on every year and you do not say what year you have.
Best bet would be a salvage yard to get all the parts you need (piping and fittings). When a lot of people remove it, they cut some of the pipes. You could also advertise in the parts wanted forum and maybe you would find someone that had removed theirs.
Old Jan 26, 2003 | 01:59 PM
brianchevy's Avatar
TB,
I am in the process of taking my A.I.R. system out of my 1987 IROC. I can ship this system to you if you want it. If you are willing to pay shipping on it, i'll send it along. BUT..
My bigger question is "WHY?" - your car will likely pass emissions without it, right? I have to pass emissions too, but the A.I.R. system has very little at all to deal with SMOG systems, it only runs the first 4 minutes until the car heats up. It's not needed for a 'sniff test'. The only way it matters if you get a visual check for AIR system... (And even then, somebody has to know what they are looking for).
SO, what do you think?
Brian
Old Jan 26, 2003 | 02:12 PM
tireburnin's Avatar
Sorry, its for a 95z.
Thanks for the response.
Old Jan 26, 2003 | 02:43 PM
Robbie's Avatar
Man i woulda gave you mine for free + shipping but i've tossed it in the trash a long time ago during my header install. Shouldnt be too hard. Ask him if they removed the metal tube that runs from the exhaust manifold to the AIR pump. As long as its still there just buying the pump shuold be all you need. Installing it is a breeze.
Old Jan 26, 2003 | 02:47 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
just make sure the car isn't cold when it goes on the sniffer.
take a few WOT runs then throw it up.
the AIR system only works when its cold/startup anyway
Old Jan 26, 2003 | 03:50 PM
tireburnin's Avatar
Thanks for the tip about running it awhile before the test.
I just want it on there for visual. The car is clean enough, just CA smog people get very picky on the visual.
-Sean
alvess
May 30, 2014 03:19 PM
camarosource
Feb 14, 2012 12:34 PM
1993Fast_Z
Jan 22, 2006 10:19 AM
Quick96Z
Jan 31, 2004 11:50 PM
107
Jan 26, 2004 08:01 PM
