Installing new CAM in '93 Z
Old Jan 25, 2003 | 01:45 PM
DjArcadian's Avatar
When installing a new CAM on a '93 is there any type of mods needed to complete this aside from timing chain, robs, rockers and springs? I recalled somewhere that you have to modify or converted the opti to a vented to fit the bigger chain on. Is that correct?
Old Jan 25, 2003 | 02:36 PM
Alvin@pcmforless.com's Avatar
If you want to use a stock LT1 timing set again you can use the stock opti and timing cover.
If you want to switch to a LT4 heavy duty timing set you will need to use a new style timing cover and opti spark.
You can always put a Hotcam in a 93 F car with no problems, you will just need to cut the dowel pin down. My method to cut the dowel pin has always been to bolt a old timing gear to the cam and mark and cut the excess off.
Which ever way you go you should replace both gears and chain.
Old Jan 25, 2003 | 02:37 PM
Also,
You do not need new rockers when swaping cams. I don't know what you mean by robs..
Old Jan 25, 2003 | 02:55 PM
swndlr27's Avatar
on the contrary
If you dont replace your rocker arms your cam will actually be smaller, the Lt-4 Hot Cam is designed to work with 1.6RR if you put it in your car with your stock 1.5's the cam will be smaller than stock
Old Jan 25, 2003 | 03:09 PM
swndlr27's Avatar
ahem
What ROOSTER93V8 was saying is correct about roller rocker arms, they dont necesarily have to be Roller Rockers, but you dont need to graduate up from 1.5's to 1.6's you could buy just the stamped version
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Jul 23, 2002 09:24 PM
