Question about the coolant cross-over pipe
Old Jan 24, 2003 | 06:46 PM
Grease's Avatar
Question Question about the coolant cross-over pipe
Has anyone tried or see anything wrong with using a pair of Aeroquip 90° AN fittings and a braided hose for the coolant cross-over pipe at the back of the LT1 heads?. Would there be enough room between the head and the firewall for one of these? Or is it even worth it?
Or do I have to use the steel line with the banjo bolts. I'm not sure wether the threads in the heads are standard or metric.
Old Jan 25, 2003 | 02:50 PM
Grease's Avatar
No one? I guess I'll have to find out on my own.
Old Jan 25, 2003 | 03:22 PM
96z's Avatar
96z
Why not just get a stocker replacement?
Here is the whole assembly's part number....12556260
Old Jan 25, 2003 | 03:25 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
yea, I dont see any good reasons to replace it with anything other than teh stock pieces. if you really want, you can cut it in half and use a rubber hose to connect the 2 heads, so you dont' have to unbolt it.
Old Jan 25, 2003 | 03:36 PM
Re: Question about the coolant cross-over pipe
The parts book lists the bolts as ".25-18 NPSF Special".
Old Jan 25, 2003 | 06:26 PM
Grease's Avatar
It was just a thought. Thanks for the part number.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
pologreen97z
Dec 2, 2014 10:42 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
