76mm A/R Question?
Old Oct 22, 2009 | 04:32 PM
boosted-lt1's Avatar
76mm A/R Question?
I'm running a Turbonetics TC76 F-1 0.96A/R on a 350 6-speed, mild heads/cam.
I'd like the car to spool faster. To me, the blower had more mid-range and came in harder than the current turbo setup. Is there a better choice for the turbine housing A/R?
Strictly a street car & also stock rods so limited to about 550-600 CSHP anyhow.
Thanks,
Scott.
Old Oct 22, 2009 | 04:44 PM
RealQuick's Avatar
Thanks,
Scott.
Hey Scott, have you exhausted the tuning efforts yet? Tuning can really help with spool. If you have, try a .68 A/r or .81 A/r. Doesn't hurt to try.
Old Oct 22, 2009 | 05:48 PM
Jon - I haven't even started tuning. Still got the FMU on it
I figure I'll try a 2-bar setup in the spring and might as well try something like a 0.81, especially with the modest goal of < 600 crank HP.
Nice score on the TIG - more options and capability is a definite plus.
-Scott.
Old Oct 22, 2009 | 10:10 PM
RealQuick's Avatar
ZDefinitely tune that puppy the right way MY BCM should be here tomorrow, so I may be able to get the shop car up and running
I can't wait to hook the tig up... I'll post pics this weekend.
Old Oct 23, 2009 | 12:48 PM
97FormulaWS-6's Avatar
That's a BIG turbo for that low of a power goal... Lower your A/R for sure should make it more inline with the power band of your motor.
Old Oct 23, 2009 | 03:46 PM
DirtyDaveW's Avatar
Is this the same Turbo as mine, TC76 w/MPS Wheel? On a separate observation, I would never think a Turbo would hit as hard at lower RPM's as a Supercharge. I think they just are different approaches.
S/C = Lots of Torque down low, good power up high(consumes a fair amount of power to drive the device.
Turbo = Moderate Torque down low, GREAT power up High(consumes no power to drive)
Some guys are making low RPM Turbo boost gains with a Turbo valve(shuts off half the scroll at low RPM's, forcing ALL the exhaust into a smaller aperture, thus spinning the exhaust turbine much faster. I believe 33% faster is the figure I'm seeing)
Thanks,
Scott.
Old Oct 23, 2009 | 04:24 PM
That makes sense. Do you think the 0.81 would be best? They offer a 0.68 also.
Pretty much. The F1 incorporates the latest Turbonetics technology to maximize exhaust energy. It's has 10 blades, extended tips, and made of 713C Inconel.
Thanks,
Old Oct 23, 2009 | 08:16 PM
MikeGyver's Avatar
A .68 is too small and will choke off a 446rwhp car, .81A/R housing is probably just perfect.
If you put the car in 2nd gear really low rpm and floor it, at what rpm does it hit full boost?
Old Oct 23, 2009 | 10:16 PM
It takes forever. Feels like a stock 350 until well into the rev range. Maybe gets into boost at ~3800/5psi and then ramps quickly to 10psi at 5000. I shift at 5500 right now.
Pretty sure the header gaskets are done. I had a bunch of the bolts back out. But it still wasn't always right. Like RealQuick said, I got to get this thing tuned. The FMU takes the motor rich almost right away. I see 10:1 AFR (which is max rich on this gauge) right when boost comes up ~4K.
If I get it up a little bit like 3500 and side step the clutch in second - about 95% of the time it wont even break street tires. It will usually bog and take a two count to start 'feeling like a car'.
Old Oct 25, 2009 | 02:56 AM
MikeGyver's Avatar
Ya give the .81 a try
For reference, on that same 2nd gear test, my rear mounted STS turbo was at full boost (7psi) @ 3000rpm. http://www.youtube.com/watch?v=rdjh3EY6shU
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
