Pulling Codes
Old Sep 13, 2009 | 05:00 PM
senrat89's Avatar
Pulling Codes
What do I need to pull the codes on my 89 IROC?
Old Sep 13, 2009 | 07:10 PM
A paperclip.
Should work the same as Shoebox outlines for the 1993 4th Gen's ECM:
http://shbox.com/1/dlc2.jpg
Old Sep 13, 2009 | 07:33 PM
senrat89's Avatar
Thanks for the reply. However this did not work. I have the 12 prong type but when I put the paperclip in and turn the key on the SES light just stays illuminated. I would expect it to flash according to the reply. Also the SES light on the 89 is just the words illuminated from behind with a light. With this said the flashing would be what I am looking for correct? As it is not able to give me trouble numbers.
Old Sep 14, 2009 | 05:27 AM
Yes.... the light behind the SES opening should "flash". Count the flashes. If it doesn't flash. the ECM is not entering diagnostic mode. Next step would be to try an OBD-I scanner, like the AutoXray.
Are you sure your SES light is working? Does it light up for a few seconds when you turn the key "on"?
Old Sep 14, 2009 | 04:20 PM
senrat89's Avatar
It remains constant when I turn the key on.
lt1matt
Mar 21, 2015 07:35 PM
Fatdog2
Feb 13, 2015 08:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
