What resistor to step 12 volts down to 2?
Old Jun 20, 2009 | 05:34 PM
Mikes 1994 z28's Avatar
Im not sure what ohm to use. Does anyone have the calculation for figuring this out? Google is failing me...
Im hooking up LED light indicators on some on my switches (fan, fuel, ex).
EDIT: Nevermind. Found my answer here http://www.theledlight.com/ledcircuits.html
LED calculator
http://metku.net/index.html?sect=vie...calc/index_eng
Old Jun 20, 2009 | 10:51 PM
RUDEDOG's Avatar
http://www.raltron.com/cust/tools/voltage_divider.asp
Old Jun 21, 2009 | 12:11 AM
dhowdy's Avatar
You'll need a resistor wired in series that is 5 times the equivalent resistance of the rest of the load essentially.
Old Jun 21, 2009 | 12:17 AM
MikeGyver's Avatar
LEDs are current controlled devices, a series resistor is used to limit current, not voltage.
Old Jun 27, 2009 | 03:49 PM
Crap, I had no idea about this. Makes sense. Thanks
Old Jun 28, 2009 | 01:18 AM
MikeGyver's Avatar
You don't need, or want to use a voltage divider to power an LED. Again, LED's are current controlled devices. You limit the current to the LED through a series resistor.
Using ohms law you can calculate the resistance needed (i.e. 13v/25mA = 520ohms). Led's have a rated forward current you should shoot for.
Being semiconductors, LED's do not have a linear relationship of voltage to current as many other things do. A small overvoltage percentage could result in double the current flow or more, burning out the led.
Old Jun 28, 2009 | 10:52 AM
The easiest thing to do is buy LEDs that are rated for 12v usage.
Old Jun 29, 2009 | 12:51 AM
MikeGyver's Avatar
No LED has a rated forward voltage of anywhere near 12volts. They simply have the appropriate resistors (usually around 400-500ohms).
Old Jun 29, 2009 | 05:19 PM
I'm pretty sure that's what Rob/Shoebox meant. Simpler is always better, when the detailed tech explanations don't seem to be getting through. KISS
http://www.radioshack.com/product/in...ductId=2062569
WobblySausage
Oct 7, 2015 02:44 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
Bxlt1
Sep 17, 2015 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
