Scan error codes
Old May 29, 2009 | 08:34 PM
Blinky's Avatar
Scan error codes
Is there a free software I can use to scan the SES error codes on my 94 LT1? I have a USB ALDL cable and use tunercat for for PCM programming. I tried Freescan and it would not connect to my car, is this because I am using a USB cable? Any other free programs out there?
Old May 30, 2009 | 03:18 PM
bobdec's Avatar
It should work, did your USB cable come with a driver, make sure it's installed. Set up FreeScan to the same COM port your PC uses for the USB connection. Select the force data 'interact' radial button on the control screen. ALSO you can try TTS Datamaster EE free download for first 20 scans/logs...
DirtyDaveW
Dec 1, 2016 05:37 PM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
aj2494
Mar 12, 2015 10:17 PM
91Bird305
Aug 5, 2002 01:39 PM
felo72
3rd Gen / L98 Engine Tech
Jun 10, 2002 01:46 PM
