Cam finally installed! Question
Old May 18, 2009 | 08:56 AM
Chrome383Z's Avatar
After talking about it for about 6mo I finally took a weekend and threw this G5x2 in.
Do people still drill the throttle bodies anymore or is that an old practice? It needs tuned bad, but I didn't know if that will help or not because I have a drive that's a little over an hour to my tuner with a lot of stoplights...
Maybe I should take a country route even if it is a little longer. !
Vid of the idle just for kicks (112 lsa):
Old May 18, 2009 | 10:00 AM
Rice Killer87's Avatar
I wouldnt drill anything unless whoever is going to tune it tells you to do so.
Since its got a lot of stoplights on the way, practice your one foot on the brake, one on the gas skills b/c your gonna need 'em !
Old May 18, 2009 | 10:17 AM
WhiteHawk's Avatar
Isn't there a set screw you can use to open up the throttle body a little? I would just do that until you get it tuned. A good tuner should be able to get that idling fine without drilling a hole.
-Geoff
Old May 18, 2009 | 10:50 AM
johnny6's Avatar
Sounds good. Definitely don't drill a hole, there's really no need because the tuner should take care of it.
Old May 18, 2009 | 11:05 AM
Chrome383Z's Avatar
Cool, that's what I thought but wasn't 100% sure. Thanks guys!
Old May 18, 2009 | 11:09 AM
Chrome383Z's Avatar
Yeah, I took it for a short drive yesterday and found that out. It's not bad if I creep to a stop REAL slow; but if I have to stop quickly or even normal for that matter = stall.
Old May 22, 2009 | 07:55 AM
teke184's Avatar
adjust the throttle screw, then reset the TPS sensor (unplug and turn ign on for 20sec)
will probably help considerably
oh...and get an early AM appointment at the tuner...and drive it at night...then sleep in the car.
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Noenav
Dec 6, 2014 07:35 PM
