trouble code p1361? help!!!!!
Old Mar 28, 2009 | 01:27 AM
96' Formula WS6's Avatar
ok i have a 96 lt1 with a deltec opti direct kit on it ( coil packs). well the car started backfireing then eventully shut off today. i ran the codes on my hypertech an i got this code.ive looked at a couple of post on here about this code. ive checked all wires dealing with the deltec kit, all wires look good. could it just be a bad coil? any help will be greatly appreciated
Old Mar 28, 2009 | 10:02 AM
well just callin around an wut i read on here its most likely pointing to the icm. problem is its a deltec kit on it an the icm is difrrent then stock gm icm. and i just learned that deltec went out of business. where can i find replacement deltec parts?
Old Mar 28, 2009 | 12:17 PM
Originally Posted by 96' Formula WS6
...where can i find replacement deltec parts?
I don't know that you can.
Old Mar 28, 2009 | 01:25 PM
well reading up an talkin to some people formilar with the delteq kit, its pointing to the optical sensor in th opti? i thought with the delteq kit, the car dosent reley on the opti anymore? im sorry im still new to 4th gens an optis. can that cause my car to run like it is?
Old Mar 28, 2009 | 05:59 PM
Opti is still required. The Delteq requires the optical sensor (back 1/2 of the Opti) output to set the spark timing. It does not use the cap/rotor (fornt 1/2 of the Opti) high voltage function.
And, your PCM still needs the optical pulse signals to set the fuel injector timing.
If the Opti optical sensor was not producing the low resolution pulse pattern, the engine would not run. But the PCM would set code P1371, which you don't have.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
