2 Codes P0100 and P0303
Old Mar 27, 2009 | 10:45 PM
sherwinZ28's Avatar
I've searched and found the first one is for the MAF sensor which I will diagnose since Injuneer posted many times on how to do. However P0303 comes up with nothing in the search...any ideas?
The scantool says Cylinder 3 misfire...why would that cylinder misfire. I've just recently changed to a new Opti and thats when these codes started.
Thanks,
Sherwin
Old Mar 28, 2009 | 09:12 AM
moparman's Avatar
Cylinder three could have a bad plug or wire. Check that the plug wire is securely snapped on the opti and plug.
Old Mar 28, 2009 | 06:04 PM
Cylinder 3 could also have a faulty injector, loose valve, etc. The code is not limited to misfires due to ignition. It detects misfires for any reason, by matching the output signal of the crank position sensor to the known irregularities in the crank's rotational velocity, as a function of the firing of the cylinders.
Also, check the end of the wires for corrosion.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
