voltmeter all the way up
Old Jan 5, 2003 | 05:10 PM
camaroKid223's Avatar
Unhappy voltmeter all the way up
my voltmeter is reading all the way up well into the red, how bad is this, what could it b, and is there anything i could to to fix it (keep in mind im 16 and dont know to much yet, still tryin to learn)
thanks
Old Jan 5, 2003 | 05:17 PM
ibanez6rg's Avatar
Hey what's up, I'm from Wilmington too! Slap another battery in there and see if it still does it. You could have a short or something or the gauge could be just screwed up.
Play around with it a litte and see if anything get's the gauge out of the red.
Is it in the red when on Accessory? Could be a alt. problem.
Old Jan 5, 2003 | 08:33 PM
ibanez6rg thanks for the reply. ok i checked out the battery its good. i think when the key is in the acc spot it still jumps up but its snowin kinda hard so ill have to look tomarrow to make sure. im thinkin it might be the alt. from time to time the gauge will go down a little under the red but that doesn't last long. anyway how much am i lookin at for a new alt, and would i b able to put it on my self or should i take it to a shop. is there anything else it could b before i go get a new alt.
ibanez6rg what part of wilm u from, cant b to far wilm's not that big, thanks 4 the help.
Old Jan 5, 2003 | 09:04 PM
ibanez6rg's Avatar
The alternator is easy to replace, took me maybe 10-15min in my 3.4. I got mine at AutoZone for around $80. You can take it out and take it in there and they will check it out to see if it's working for free.
Hook a voltmeter up to the alt. and you can see what it's really putting out, incase your gauge is not working.
The Wilmington thing, I'm from Wilmington, Ohio.
Otherwise I would come over and help ya out!
Old Jan 6, 2003 | 02:10 PM
thanks 4 the help i will put another voltmeter to it like u said to c if its just my gauge (hopefully) then if its the alt replace it. again thanks 4 the help
ss00
Apr 10, 2006 07:04 AM
MOZ28
Apr 1, 2006 02:43 PM
Mirrorsaw
V6 Tech
Feb 4, 2004 02:58 PM
Mirrorsaw
Jan 31, 2004 07:18 AM
katman
Dec 2, 2002 12:00 AM
