voltmeter low....
Old Mar 31, 2006 | 02:38 PM
MOZ28's Avatar
voltmeter low....
I was driving around the other day and i noticed that the voltmeter was lower than normal. Also, my gauges kind of jump up when im accelerating, and sometimes the car jerks forward when accelerating too. whats the deal, what needs to be fixed??
Old Mar 31, 2006 | 11:13 PM
MOZ28's Avatar
Re: voltmeter low....
so.....new battery, would that work?
Old Apr 1, 2006 | 03:26 AM
HungryT/A's Avatar
Check your alternator first, make sure it's delivering 14.4V.
Old Apr 1, 2006 | 08:23 AM
n2ceptor's Avatar
Sounds like the battery needs to be replaced..... Just take it to your local auto parts store and have it "load" tested.... If it checks out ok, then check the alternator, the vehicle running at the battery with a multimeter.. Voltage should read between 13.8~14.2 give or take a point....
PS. Dont forget to check for loose wiring or corrosion first...
Old Apr 1, 2006 | 02:43 PM
Josh-'04 GTO's Avatar
I would go right for the battery and alternator and check the connections for corrosion...
ss00
Apr 10, 2006 07:04 AM
matLT1
Apr 30, 2005 05:41 AM
Mirrorsaw
V6 Tech
Feb 4, 2004 02:58 PM
Mirrorsaw
Jan 31, 2004 07:18 AM
katman
Dec 2, 2002 12:00 AM
