Voltmeter woes in the freezing cold..
Old Jan 30, 2004 | 06:36 PM
Mirrorsaw's Avatar
Hey guys..
I recently bought a new battery along with a JL stealthbox system that is at 250RMS watt power.
It has been consistently below freezing here in new york.
My problem is this - The car is always extremely low on electric power now. My voltmeter is consistently hovering above the lower redline with just my headlights, heat, and the sub on.
With this stuff off, the power goes up considerably, but I can visually see a huge drop in the voltmeter whenever I turn one of these things on.
Heavy bass hits from the subwoofer will visibly lower the voltmeter needle.
My question is this - What the hell? The system I put in my car is basically bottom of the barrel concerning the amount of power it utilizes. On top of that, I have a new battery in there. Every time I drive around, I'm scared my car is going to die, and I have to travel long distances without my heat on to keep it up a bit.
The power will go up just fine when I'm driving, but when I come to a stop with the car on, the voltmeter goes way down to the lower redline, barely above it, sometimes entering it..
I'm wondering what I can do to fix this situation. I can't keep driving with such little electricity and worrying all the time about it. There's no reason why my power should be so low just because I put a very low power sub in there.
I'm thinking it's just the cold? Maybe someone else is having this problem around the Northeast? Help, please.
Here's some info:
Cheapo Walmart battery (eh, it's new at least)
Alternator is around 100,000miles old..has not been rebuilt
250RMS Watt JL 250/1 Amp, with JL 10" stealth enclosure
1996 Chevy Camaro
- Problem occurs even after fully/partially charging the battery with a battery charger..
- I have checked my amp connections..power and ground cables are in tight.
Old Jan 31, 2004 | 07:18 AM
LS1 RULZ's Avatar
Start by having your car's charging system checked out.
Formula Steve
Sep 19, 2023 08:31 AM
damnyankee36
Sep 9, 2015 07:06 PM
zxtce
May 7, 2015 08:53 PM
camaroKid223
V6 Tech
Jan 6, 2003 02:10 PM
katman
Dec 2, 2002 12:00 AM
