1991 3.1 RS Problem
Old Nov 2, 2008 | 11:41 PM
odommcdee's Avatar
1991 3.1 RS Problem
Ok, my 3.1 is overheating and idle is off. Car barely starts up. I just had new spark plugs and wires put on it. I ws wondering if it could be the egr valve?
Old Nov 3, 2008 | 12:01 AM
odommcdee's Avatar
anyone?
Old Nov 3, 2008 | 05:11 AM
Please do not repost within 20 minutes, particularly near midnight (EST) when there's not as many people on the board. General guideline is to wait 24 hours before pushing your post back to the top.
My first guess would be a faulty coolant temperature sensor, not giving the ECM the correct engine temp. An EGR valve that is stuck open will cause it to idle poorly, or even stall. But it isn't going to make it overheat.
Under what conditions does it overheat - at idle in heavy traffic, at freeway speeds, under wide open throttle, all of the above? Can you hear the fans come on?
Have you scanned it for codes? That would be a good place to start?
Old Nov 3, 2008 | 11:03 AM
odommcdee's Avatar
its overheating on all of the above.
Old Nov 3, 2008 | 11:43 AM
odommcdee's Avatar
i mean it is idling heaving on all of the above and is overheating in traffic at lower rpm.
A's 91 Z28
Jan 11, 2015 10:58 AM
slimdawson
Aug 25, 2002 10:10 PM
91 Redd Sledd
Aug 3, 2002 11:50 AM
91Bird305
Aug 1, 2002 03:35 PM
