Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
dirty fuel line question
Old Oct 25, 2008 | 10:46 AM
football4life's Avatar
Hi, Im finally finished my 94 rebuild. Now im messing with the fuel system.The car has been sitting for 7 years with gas still in it. So, I pulled the tank cleaned it and replaced the fuel pump. Now I am wondring is there any way to clean the fuel lines running up to the engin bay? Maybe like pumping acetone through them? or would that damage the fuel lines. Or should I just forget about It because it should not be too big of a deal and just run clean gas through the lines?
Thanks Josh
Old Oct 26, 2008 | 10:04 AM
I wouldn't put acetone in the fuel lines. Why not just use a bottle of fuel injector cleaner? You know that's designed to be harmless to the fuel lines, and to act as a solvent to the materials that would normally clog the fuel lines.
Old Oct 26, 2008 | 10:24 PM
sounds like a good idea. I was just worried about the gas turning to sludge in the lines. Do you think that injector cleaner would be enough to get the job done?
Old Oct 26, 2008 | 11:16 PM
mrmint69's Avatar
If you use enough and do it correctly. You should be able to see what is coming out and stop when it appears to be clean.
HectorM52
Jul 30, 2017 11:46 AM
Patricklt1
Apr 24, 2015 06:29 AM
Deadbolt24
Jan 19, 2015 01:29 PM
Jul 4, 2005 05:00 PM
