Transmission ???????
Old Oct 20, 2008 | 05:29 PM
Trent_speed's Avatar
i have a 95 camaro z28 and my 3rd and 4th gear went out and now i have to rebuild the tranny on it and it will cost 1300. so im just thinking i should buy a used tranny but im wondering if like any of the v6 transmission will fit or even work on a lt1 motor. like the 3.8 or 3.4 cuz im 17 and dont have that kind of money right now. there isnt any z28s in the junkyard around here
Old Oct 20, 2008 | 07:29 PM
Probably not getting responsed because you're on the wrong forum. I'll move your post to the "Drivetrain" forum.... a lot of A4 pro's there who can help you out.
Old Oct 21, 2008 | 12:51 AM
Performabuilt's Avatar
Supporting Vendor
You can use V8 transmissions only and it will actually need to be from a 95 to avoid mods
You can use them from the following vehicles
1-Any V8 camaro
2-Caprice and impala V8 and 4.3 V6
Any of these should be direct swaps for you other than swapping the tail housing "4 bolts"
Old Oct 21, 2008 | 10:15 PM
well what happens is that it shifts fine in first then to second but then it has know 3rd or 4th. isnt the shifting electronically so could it be a fuse or something other than the tranny please help.
Old Oct 22, 2008 | 01:34 AM
mccauls_ss_camaro's Avatar
sil-in-nod-e sorry dont know how to speel it theres 2 in the tranny try replacing but there should b a cheak engine light on
Old Oct 22, 2008 | 12:13 PM
dStruct's Avatar
You can pull the dip stick and check if the fluid is red/pinkish, it should look clean and smell sweet sorta. If it smells burnt at all or has particles in it then it's definitely time for a rebuild. It's a pretty common issue to have 3-4 burn up. Is it the original transmission?
If it was a progressive problem that got worse and then finally didn't work at all, then yeah it's most likely going to be the 3-4 clutch pack. I had a similar problem with my 4L60E before I had it rebuilt, and honestly you're going to spend a ton of money at a salvage yard to get a worn out transmission, go to all the trouble of installing it, and just have the exact same issue again down the road.
I'd highly recommend getting it rebuilt or replaced with a new one. Have you seen CPT or PerformaBuilt's website? They offer some of the most affordable rebuilds that I've ever seen and from what I've read on the forums here they seem to hold up to the abuse pretty good.
Good luck
Old Oct 24, 2008 | 12:25 AM
SpeedZ28's Avatar
There's a guy who had one on ebay last week i almost bout it cause mine just went bad, but i paid the 1300.00 to have a shop i know do it, anyway...he's got a store on there called transmission depot, he was offering a rebuilt 4l60 for 699.00 + 179.00 shipped with a 12 year 12,000 mile warranty heres what some of it said
COMES WITH:
# Free Torque Converter 1800-2100 Stall
# Competion Shift Kit Stage 2
# Heavy duty HIGH ENERGY clutch packs
# New Detent Cable
# Heavy duty sprag
# Updated sun shell
# Updated Pump Assy.
# Complete bushing kit
# Corvette Servo
# No wiring needed lockup automatic
# 500 boost valve
# Up to 575 HP
anyway, I agree with dstruct your going to be in the same boat if you buy a used one.
Good luck.
Old Oct 24, 2008 | 08:46 AM
Supporting Vendor
COMES WITH:
# New Detent Cable
# Heavy duty sprag
# Updated sun shell
# Corvette Servo
# 500 boost valve
# Up to 575 HP
Good luck.
4L60Etrans don't have detent cables and we cant even buy the parts and core to build it for that much less labor etc , Hes either giving them away for less than what he has in them which I doubt or theres something wrong here
Old Oct 29, 2008 | 02:48 PM
SpeedZ28's Avatar
Yeah....you never know with ebay I guess, thats why I just paid a well known,trusted, local shop to do mine. Times are hard, work is slow, hate to spend the money but gotta do it. Did sound a little to good to be true eh.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
