What size wheel and offset for Narrowed 12 bolt?
Old Aug 13, 2008 | 12:12 PM
DRIVEFASTKEEPLEFT's Avatar
I'm looking into buy a narrowed 12 bolt that has been shortened 3" on each side. It has fit into a 4th gen lt1 car and has all the provisions for LCA's, TA Brakes ect. Right now I have a 15/8 welds with a 5.5 backspacing. If the rear end is narrowed 3" on each side, and I want to run a 10" rim, will a 15/10 with a 3.5 backspace be okay? I want this to go in with no cutting of anykind. Let know what you think. Thanks in advance.
Old Aug 13, 2008 | 06:14 PM
15 x 10 Welds require a 7.5" backspace with a stock 4th Gen rear axle assembly width. If you narrow the rear by 3" on each side, you will need a 4.5" backspace, to put the tires right where these are:
Running a 3.5" backspace will move the tires about 1" outside the fenders..... maybe slightly less if you are running a tire narrower than what's in the picture (ET Drag 28 x 10.5 - 15W).
Old Aug 13, 2008 | 07:37 PM
Injuneer.
Thank you so much for the info. I want exactly what you have. If I end up doing this, I'll need to get the 15/10 with a 4.5 BS and do a ET Drag 28 x 10.5 - 15W. The tire looks real good on the car. Everything else I would hope will match right up like my LCA's, TA, driveshaft and ebrake.
Old Aug 13, 2008 | 10:17 PM
I had to cut the bumper cover to fit that tire in there. The axle assembly had already been moved back 1/4" when I was running Hoosier QTP 28x11.5-15's. They grew enough when trap speed went over 125MPH that the tire tread was rubbing on the metal leading edge of the fender opening.
Old Oct 29, 2008 | 03:54 PM
mehoffz24's Avatar
injuneer,
when you moved the rear back 1/4 inch did you ever worry about the driveshaft yolk pulling out of the trans? or when you had your shaft made did you have a longer slip travel just for that reason?
so since you can fit that wide of a tire under under the fender lip is there any real reason to narrow the rear?
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Hoodshaker
Aug 27, 2002 02:32 PM
Z28 97'
Aug 4, 2002 09:43 AM
