turnsignal not blinking
Old Sep 13, 2008 | 01:48 PM
saitin's Avatar
well my left turn signal doesn't blink when I click it on it just stays lit up solid but when i click my right signal on it blinks perfectly.
Old Sep 13, 2008 | 01:51 PM
Sick97SS's Avatar
You have a blown bulb. Check ALL the bulbs on the left side. Sometimes they'll look ok but are really blown. If you're sure it's not a bulb issue then it's a bad blinker relay. But 9/10 times its a bulb.
Old Sep 13, 2008 | 01:55 PM
saitin's Avatar
I went through and replaced all bulbs on the car
also the hazards blink perfectly just the left blinker doesn't do teh blinking there is no ticking noise either.
Old Sep 13, 2008 | 03:25 PM
Sick97SS's Avatar
Problem might be in the steering column then, strange the hazards work. these cars are notorious for turn signal problem because of the cheap lever itself.
Old Sep 13, 2008 | 03:30 PM
94_PatriotRed_Z's Avatar
Might be a loose wire inside the turn signal lever
Old Sep 20, 2008 | 07:53 AM
drptop70ss's Avatar
most likely a bad socket on the tail light harness, the wire connections are flimsy and often break, usually the ground wire. Put the left turn signal on with the tail lamp removed and the bulbs hanging free. and get a spare piece of wire a few feet long. Touch the wire from the car on a clean grounding point to each turn signal bulb's metal base one at a time. The signals will start working when you find the bad socket, then replace it or the harness.
hackman
Jun 7, 2015 10:31 PM
pimpinphil
May 30, 2015 04:20 PM
csabatka1
May 29, 2003 10:56 PM
kev93z28
May 4, 2003 07:26 PM
Formula_one
Jan 30, 2003 08:04 PM
