T56 donor cars
Old Jun 19, 2008 | 08:16 PM
LearJet's Avatar
T56 donor cars
Other than the obvious F-body, are there any other vehicles GM made that I can get all the parts needed to swap from an A4 to a T56? I think I am tired of dealing with this tranny.
Old Jun 19, 2008 | 11:31 PM
The only T56 that will bolt directly to your 97 would be on out of a 93-97 LT1. And the two versions of the T56 used in the 93's both have much lower (higher numerical) 1st gear ratios, and a reduced torque capacity compared to the 94-97 T56's. The LS1 T56 has a longer input shaft, and uses a conventional "pusher" style clutch, compared to the LT1's unique "pull back" design. The Corvette T56's are a totally different configuration, mounted in the rear of the car, bolted directly to the differential housing.
Old Jun 20, 2008 | 06:08 PM
LearJet's Avatar
Roger that, look for a LT1 F-body in the junk yard then....Those are not good odds
Old Jun 20, 2008 | 06:17 PM
pyro719's Avatar
You would be better off sending your trans to frank @ CPT $1,000 gets you a real nice tranny!
Old Jun 21, 2008 | 08:55 AM
LearJet's Avatar
How would that help me go from a auto to a stick???
Old Jun 21, 2008 | 09:44 AM
Car Enthusiast's Avatar
or have a better tranny?
just keep looking on here a tranny will show up
Old Jun 21, 2008 | 12:22 PM
Green96Z's Avatar
You could buy a complete tranny, core and all. That's what I did. Got mine from Six Speeds Inc. You can also look into D&D Performance, I believe they sell a complete T56.
cmdeshon
Dec 27, 2014 10:06 AM
nballisru
Dec 14, 2014 05:01 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
USAirman93
Nov 24, 2014 03:37 PM
slothgrant
Aug 22, 2002 03:01 PM
