'Drill mod" Pix?
Old Jun 14, 2008 | 08:08 PM
LJM97Z's Avatar
'Drill mod" Pix?
I'm looking into doing this so my M6 will shift into 3rd. easier while raceing it, does anyone have pix of or info on what needs to be done?
Thanks.
Old Jun 14, 2008 | 09:50 PM
seawolf06's Avatar
Do you have an LT1 or an LS1? This mod is only done on the LS1 cars. It will not do anything on your car. You need to have your tranny looked at before you damage anything more.
Old Jun 14, 2008 | 11:09 PM
96m6lt1's Avatar
the mod is for Ls1 cars...
if you have difficulties getting into 3rd gear you may have an internal problem,possibly have a loose shifter.........
Old Jun 14, 2008 | 11:36 PM
LJM97Z's Avatar
See, this is news too me, when i had ask about this awhile back (forgot to save the thread), i wasn't told anything about it only working on an LS1, its not that it doesn't shift good, just under higher RPMs, running through the gears at the track, it will sometimes just STOP in "N" when trying to shift fast too 3rd., sometimes its fine, i was told all it needed was the "Drill mod". The shifter is a B&M shorty, it feels tight, i'll look & see if anything is loose.
Old Jun 14, 2008 | 11:51 PM
Green96Z's Avatar
If you have problems shifting into 3rd, you probably have a bent 3-4 shift fork. It's a common problem with these trannies. Have it looked at. And yes, the drill mod is only for the LS1 hydraulics.
Old Jun 15, 2008 | 12:27 AM
LJM97Z's Avatar
Is this something i can do myself, does the tranny need to come apart? Whats all involved?
Where can i find Pix of the shift forks?
Old Jun 15, 2008 | 12:56 AM
mpe331lx's Avatar
Yes it has to come apart, but you can do it yourself with the right tools.
It could be a bent fork (upgrade to a steel 3-4 fork and put bronze pads on it and the 1-2 fork). It could also be the cheap stamped steel keys in the 3-4 slider. It is very common for a t56 to chew tham up and make it hard to go into gear. Get a new 3-4 slider, new blocker rings and a set of billit keys to put in the new 3-4 slider.
Here are a couple links:
http://www.gmhightechperformance.com...ild/index.html
http://www.noid.org/~lj/T56/T56.htm
slider
billit slider keys
3-4 steel fork
bronze pads
carbon blocker ring kit
You will need a quality set of knurled snap ring pliers, a custom long arm two jaw puller and a press.
Here is a link to the type of snap ring plier: knurled snap ring plier
Old Jun 15, 2008 | 01:12 AM
LJM97Z's Avatar
slider
billit slider keys
3-4 steel fork
bronze pads
Thanks for the info
Old Jun 15, 2008 | 10:26 AM
We have a "Drivetrain" fourm....
Moving.
Old Jun 16, 2008 | 10:03 AM
chevyinside's Avatar
I did this to my lt1 hyd. and it improved it . your just drilling out the restriction on the master cyl side . i cant remamber wht size the drill bit is though.
Old Jun 18, 2008 | 05:39 PM
LJM97Z's Avatar
Yeah, thats what i was talking about, if i remember, you had to drill out the line itself, i heard it really helped with the 2-3 shift.
Old Jun 19, 2008 | 01:34 PM
95TALT1's Avatar
what and where do you drill out
Victor Lamb
Aug 26, 2017 02:52 PM
FryedClutch
Sep 1, 2015 08:24 AM
realistyc
Jul 28, 2015 07:32 PM
Jul 10, 2015 02:23 PM
alex5366
Jun 7, 2015 08:50 AM
