AC problem
Old May 25, 2008 | 02:11 AM
StylinZ's Avatar
AC problem
Got a 94 camaro V6. The controls that contorl the position of where the air comes out doesn't work. no matter where you put it it blows out the defrost and bottom. Any ideas?
Old May 25, 2008 | 02:10 PM
gnomee's Avatar
Its a vacuum leak.
Just to the right of the PCM under the hood there is a vacuum hose that goes to a little round T one goes inthe firewall the other goes towards the motor. I had a problem with the T cracking and causing this same issue. It could just be the T or it could be the line got disconnected from the intake.
Old May 25, 2008 | 02:16 PM
StylinZ's Avatar
thanks i'll check it out and see
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
