3.23 to 3.73 swap?
Old May 7, 2008 | 10:43 PM
pcgamer4life's Avatar
3.23 to 3.73 swap?
I got a set of 3.73's out of an S10 blazer today at the junk yard, they're in pretty good condition... main question is am I going to need a ring gear spacer? Since they're the same series carrier they should just drop right in, correct?
Old May 7, 2008 | 10:56 PM
bombebomb's Avatar
Yes you are correct im pretty sure. Im about 99% sure
Old May 7, 2008 | 11:03 PM
Well then, another question, are there any downsides to using GM gears as opposed to double-priced aftermarket gears? I really don't see how there really could be much.
Old May 8, 2008 | 03:29 AM
bombebomb's Avatar
Well, I do believe useing GM gears if installed right they will not howl like aftermarkets (which occasionally do not howl). I do not know if there is a difference myself.
Old May 8, 2008 | 09:47 AM
FirstYrLS1Z's Avatar
The 3.73:1 pinion you pulled out,does it still have the bearing(with shim underneath it)on it? that shim would be your starting point for 'pinion depth'
I prefer blazer used 3.73 gears over aftermarket used 3.73 gears.
Old May 8, 2008 | 12:08 PM
Yeah, it's still got the bearing. Not sure about the shim, I would assume so though. We'll be putting the gears in this weekend. A buddy of mine has done it twice, but for a solid install, is there a guide to proper procedure?
Old May 8, 2008 | 05:28 PM
sl2racer's Avatar
i found this one
http://www.chevyhiperformance.com/te...all/index.html
Old May 8, 2008 | 10:17 PM
Thanks for that, I found another guide out there and they mesh pretty well together. I'm just going to need a bit more instruction on setting backlash and pinion depth... I'll keep reading on
Old Apr 17, 2011 | 06:59 PM
canuck94z28's Avatar
Re: 3.23 to 3.73 swap?
Can you provide any updates.How much were the gears?what are the pro,s/cons?Any info will be appreciated.
Old Apr 17, 2011 | 07:45 PM
You might want to try and e-mail him. pcgamer4life has not visited this site since 11-14-2010.
Left click on his name, and it will offer you the option to e-mail.
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
